Old 07-21-2005, 03:40 PM
Green1995SVX
Originally Posted by soobiesvx93
96 svx's do not have a power light
1234567890
Old 07-21-2005, 03:58 PM
Originally Posted by nordique14
96 & 97 models are ODBII and do not have a power light. You will need an ODBII reader to get the trouble codes.
The CEL being on will usually indicate an emissions problem. That can sometimes be an expensive fix, so get it checked out before you buy. Here in California, they will not pass a car for smog if the CEL is on.
Good luck in the hunt for an SVX.
-Matt
1234567890
Old 07-21-2005, 05:34 PM
pavanbabut's Avatar
Old 07-21-2005, 08:30 PM
RedHotSVX RedHotSVX is offline
gettin there....
Send a message via AIM to RedHotSVX Send a message via MSN to RedHotSVX Send a message via Yahoo to RedHotSVX
Originally Posted by Freddex
Radar,
I've already driven it! There is no light showing at all! I stepped on it and it went well but still no light. Even in the ON position there is no light. Does anyone here have a '96 SVX that shows a "power" light??
Regarding the engine light they say that they will take it to a Subaru dealer and get it read and fixed if I am buying the car.
I have a 97,and no power light.....never even noticed a spot in the dash for it.
I bought an obdII code reader made by Stinger,sells for $160,it reads codes,and will clear them also.Of course being an auto tech,it helps me with plenty of other car's also,so you might not want to spend the $.
And when I 1st bought my SVX the check engine light was on with a cylinder #3 misfire code,I cleared the code and it hasn't come back since,this was about 20k mile's ago.
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
Old 07-22-2005, 04:23 PM
scoobymal's Avatar
scoobymal scoobymal is offline
Smile
My yellow 1996 uk svx has a power light,comes on with the ignition, flashes several times then goes out,comes on when booting it,but not when in economy mode.
Mal.
Old 07-22-2005, 04:29 PM
pavanbabut's Avatar
Mal.
Overhere if it flashes like u said means there is something going bad with the transmission. If it is same in your case then have it checked up.
-Pavan.
