Old 06-16-2005, 08:08 PM
Engine Rebuild... Need some info on parts
I am looking to rebuild my latest fart for a motor. I just took a peek at the prices for bearing and such on Subaruparts.com and I almost want to throw the old block in the ocean. it was cheaper for me to buy a junkyard engine than it would be for to buy just bearings for the crank and conn rods alone. Anyway, is there any way I could cross-referance the EG33 with the EJ22? I mean this along the lines of crank main bearings, conn rod bearings, pins and bushings, and maybe a ring set? Aftermarket parts are always cheaper than dealer parts so i was wondering if anyone may tell me where any aftermarket parts are available. Thanks for the help guys... and by the way, there is now rush as this is a gradual rebuild so eventually i can have a superfresh motor in my car.
Old 06-16-2005, 08:30 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Tom,
You might want to PM the guy up in Alaska who posted all the pics of the EG33 he was tearing down before rebuilding it. I'd have to think that he had sources for bearing, etc. lined up.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-17-2005, 09:24 AM
do you have a name? I know there was a guy who was rebuilding his motor not too long ago but proceeded to break his pistons and blow his block apart...
Old 06-18-2005, 11:02 AM
so no one knows about any bearing and ring kits for the EG33?? Also, the conversion factor for the EJ22 bearings.. Is it possible or not worth my asking? Thanks
Old 06-22-2005, 09:10 AM
bump... common guys, someone has gotta know sumthing
Old 06-26-2005, 01:05 AM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
Try https://www.1stsubaruparts.com/ main set is $212 and rod set is $244. A few dollars cheaper than subaruparts.com but they don't have the nice diagrams.
Old 06-26-2005, 09:19 AM
mbtoloczko's Avatar
sans SVX
Have you looked at aftermarket bearing options? In particular, the Clevite Tri-metal 77 is well regarded in many circles.
Mychailo
Visit my locker
Old 06-26-2005, 09:50 AM
That is exactly what I was looking for. Thnx man i will check them out
