Old 03-25-2005, 07:17 AM
red95svx
Originally Posted by deruvian
I once read an article that talked about the test results on cars with ABS versus cars without ABS. Essentially, if one knows how to properly handle a car without it, the car can easily be stopped just as quickly as the other ABS equipped vehicle.
ABS is not about shorter stopping distances, it's about controlling wheel lockup. ABS is not activated until it senses lockup, then it kicks in. No lockup = no ABS activation. In that case a car without ABS would brake just as well as one with. But now throw a wet road into the equation. A car without ABS could lock one of its wheels, causing the car to veer to one side (which could lead to the car to spin around). The car with ABS would not allow wheel lockup, thus preventing any unwanted direction changes.
Old 03-25-2005, 08:44 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Fwd
I agree with Tom that my 94 LE will do 140+ and seems considerably faster than all of my others. It also, has by far the most miles on it. It "seems" faster in all respects, but since I have never taken it to the track I can not provide times to prove this. It also does not have ABS and I like that personally even though I admit to the ABS advantages of stopping on wet surfaces.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 03-25-2005, 09:42 AM
drivemusicnow's Avatar
Poor College Racer
The data listed above that says i have a 136 mph speed limiter in my car is not true... not saying its the smartest thing i've done, but i've gone 145 in my car... so frankly, if the top speed is wrong, what makes the rest of legit?
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 03-25-2005, 10:22 AM
deruvian
I understand that, but personally I feel just as confident driving around in wet conditions without ABS as I do with ABS. This is not the point of the conversation though.
There is absolutely no reason for the FWD non-ABS SVX to have a larger braking distance than the other models. Enough said.
Old 03-25-2005, 10:55 AM
IggDawg's Avatar
IggDawg IggDawg is offline
0h n0es!
Send a message via ICQ to IggDawg Send a message via AIM to IggDawg
Keep in mind that subaru gauges are "for entertainment purposes only" =P.
IggDawg is cool
-IggDawg
1992 Teal SVX LS-L 160k miles
4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE
1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP
ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k
Old 03-25-2005, 08:10 PM
Poor College Racer
That may be so, but i had about 3 % larger tires on the car at the time, and anyway you look at it, the guage won't be 12 mph + off
Greg
