trans adapter
Does anyone know if there is a transmition adapter to mate a suby motor to a powerglide or ford trany?
No...the Starter location prohibits it....
Is there any rear wheel drive trans that could work with a suby motor?
A Subie trans modified to be RWD. What are your plans? Making a RWD SVX, or putting the EG33 into a different platform?
I am building a pro arena racer. I want to set the motor back in the frame ( 10% of the wheel base from the center of the front diff to the face of the motor is permitted) and run the trans output shaft into a divorce transfer case and then to indipendent diffs frount and rear. The frame I am using is a nissan short bed.
Get a 95 Legacy 5spd with a 4.11 ratio. Then find a Nissan t-case with 4.11's and your set.
Prime Сasual Dating |
