Old 01-02-2003, 08:29 PM
SubaSteevo's Avatar
No longer blue member
Question Strut Options
My baby is gonna need some new struts soon, the back right is starting to leak. I'm curious as to what types of options are available right now. The Koni's are no longer available, and are expensive(atleast more than oem) correct? Are there any other options besides oem (cheaper)? I checked subaruparts.com and they have two different things for "complete strut" listed:
01 $79.97 Strut complete (rear) right hand 2x-
$193.90 Strut complete (rear) right hand -29
What is the difference? I don't think I can do them on my own, any idea on a price to have them installed? I'd really like to get all 4 done, but I probably only have enough for the rear for now. Thanks for the help.
P.S. Anyone who has done struts before is more welcome to install them for me
-Steve
01' MSM Lexus IS300
Old 01-03-2003, 03:38 PM
wawazat??'s Avatar
Yeah, I'm still around
Not many choices
I can't help with the Subaru part numbers and prices, but the Konis will be more expensive than the stock struts. There are currently no other choices, though Porter said he was working on something awhile back.
Some of the Japanese sites show a listing for an Aragosta coilover kit. I contacted Aragosta here in the states and they:
1) knew nothing about the application
2) never returned my calls after taking my info and telliong me they'd check it out.
Todd
Down to none
Old 01-03-2003, 03:42 PM
Green1995SVX
The Aragosta struts were a short batch run of struts simply for FLATT Racing in Japan. They are no longer produced, but FLATT still has them in stock.
Mike
PS-- Dont try calling Aragosta in the states... they are very rude and not helpful at all.
Old 01-03-2003, 04:39 PM
ww111
Thumbs up Koni's!
http://www.classicgarage.com/classic...svx19fron.html
I've had this site bookmarked for a while now. Until I can get enough money to liberate some of these things. Give 'em a call,
Collins
Old 01-03-2003, 05:20 PM
You could go with SHOWA, I know of someone who paid close to $1,000 to buy these, but you could get the same ones from the dealer
Old 01-03-2003, 08:14 PM
Green1995SVX
As Chris said, the stock struts are made by SHOWA, a respected name in suspension in Japan.
Mike
Old 01-03-2003, 08:18 PM
Re: Koni's!
Collins
why only for '92-'96? the '97's aren't different - are they?
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 01-03-2003, 08:24 PM
Green1995SVX
Alan- There is no difference in the suspension for 97. My guess is they dont have physical confirmation of the fit on the 97, so they dont say it WILL fit. But i would bet my clear headlight lenses that they will.
Mike
Old 01-03-2003, 08:27 PM
Mike
that's what i thought, but you never know with the SVX.....
i'll bet my cracked lens they don't - what do i have to lose? (BTW, i e-mailed smallcar.com and Brian said no word on the clear headlights yet. )
Old 01-04-2003, 12:06 PM
mbtoloczko's Avatar
sans SVX
Re: Strut Options
Its really not that hard to replace the rear struts you have a garage where you can do the work. You'll have to put the car on jackstands to do it. As long as the bolts securing the strut to the knuckle are not seized from rust, replacing the rear struts is pretty easy. Two bolts securing the strut to the knuckle, three nuts securing the strut to the chassis, and one bolt securing the brake line to the strut. Seized or not, you'll need a good size breaker bar to loosen the bolts attaching the strut to the knuckle. Oh, and you have to disassemble the rear of the interior of your SVX to get to the strut-to-chassis bolts. (They're under the rear deck panel.) That's not hard though either if you're patient. Probably the most difficult part would be pulling the spring off the old strut and mounting it on the new strut. You'll need some sort of tool to compress the spring. I used two pieces of nylon rope (on opposing sides of the spring) and two bars (tightened the rope by twisting the rope around using the bar). Worked perfectly. The spring replacement job is best accomplished with the help of a friend. When you put the new struts on the car, make sure you put them on the correct side of the car. :-)
If that sounds like its out of you're realm, then call your local mech and ask for a quote on strut replacement for an SVX.
Mychailo
Visit my locker
Old 01-04-2003, 12:14 PM
svx_commuter's Avatar
I have done 10 strut replacements. Piece of cake if you got the right tools.
Check your rear strut mounts before you get parts. They may be rusting away. You may also want the upper stut mount/bearing for the fronts. You may also want to replace the spring rubber if the mating part has rusted real bad.
Old 01-04-2003, 02:52 PM
Subafreak's Avatar
Superbeast
I think someone said something about Legacy/ Impreza struts going on SVX spindals, just that the SVX spindals were just a little thicker but the bolt spreads were the same. If so you could just have the spindals shaved down to fit. There are a lot more strut options for Legacy/ Imprezas. Has anyone tried to see if this would work yet.
Old 01-04-2003, 05:13 PM
$VX
Thats weird. You think KYB or Gabriel etc etc would jump at the chance to make struts for our cars; they could undercut the factory price and give us a better strut.
- Ca$h
Old 01-04-2003, 05:32 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Maremont/Gabriel does make struts for the SVX. They're just too dang expensive (last I checked about $157 ea.) for what they are. The factory struts are the best value so far.
Old 01-04-2003, 09:43 PM
SubaSteevo's Avatar
Part numbers...
I think I might try the job myself, anyone know the difference between those parts I asked about?
-Steve
01' MSM Lexus IS300
