Old 12-05-2011, 08:50 PM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
5 speed tranny diagnose?
Maybe I should just leave my SVX alone but I can't.
One member pointed out to me that there are two WRX 5mt trannies within 4 hours of me. That's practically next door for Wyoming, where I live. A sign?
Anyway, I haven't called the seller yet but I'm wondering if anyone has any tips on how to look over the 5mt for defects. I've read a bit on rear seal and bearing failure, 2nd gear problems. Apparently, one of them has the improved 2nd gear.
Any thoughts on diagnosis?
Old 12-06-2011, 01:04 PM
Re: 5 speed tranny diagnose?
it's hard to tell much with the trans out of the car except if it turns well and does or does not leak. the best method i have found is to find out as much about the car it came from and the driver who had it. if they have a boost controller or totaled the engine you know they abused it. anything like this works. i even try to find an excuse to have them give me a ride in their car (to auto parts store or act really interested in what they drive) to see how they treat their current car. this will tell you as much as you can find out without taking the trans apart. if they let you drain the fluid to check the condition but a lot of people won't let you do that unless you pay to fill it back up if you don't purchase the trans. if they agree forget to bring the fluid and have them drive you to auto store to pick some up.
Old 12-06-2011, 01:29 PM
Huskymaniac's Avatar
Uses the ignore feature
Are either of them from a 2006 or 2007?
Tony
Old 12-06-2011, 05:33 PM
The WRX 5-speed you want is from an '05.
Old 12-06-2011, 10:52 PM
WYOSVX's Avatar
I'm not very good at the little purchasing games but I'll have to give it a try if they're for sale for very long. Thank you.
One is definitely from an '05 WRX and he suggests that both are, why?
Old 12-07-2011, 09:19 AM
http://www.northursalia.com/techdocs...rannychart.pdf
Have a look at this chart.
The '05 USDM WRX 5-speed has the 1.1:1 center diff that lets you use the stock SVX 3.54 rear diff. It also has the high 5th gear that is a good match for the EG33. The EG33 has a lot of low-end torque, so it does well with a high cruising gear. The 02-early 04 ones had a lot of issues, but the '05s had all of the revisions, so it should be very solid.
If it's an '05 and seems to be in good shape, then I'd go for it. Check the serial number on the trans and make sure it matches the serial number in that pdf I linked.
Old 12-07-2011, 10:30 AM
sunvalleyray sunvalleyray is offline
Question...I thougth that the WRX 5 speeds were upgraded in late 2004? Is this true or am I misinformed?
Ray
Old 12-07-2011, 10:35 AM
They were, but I don't think there's any way to tell that a given '04 is one that's gotten all of the updates or not. (Could be wrong). '05 is a safe bet.
Old 12-07-2011, 08:00 PM
WYOSVX's Avatar
Wow! Many thanks!
If this one doesn't work out, I sure have a MUCH better idea now.
Old 12-07-2011, 09:29 PM
Anytime.
Actually I was wrong, the 04s that have the updated guts have a different trans serial number according to that chart.
BTW that chart is not complete and may not be 100% accurate, but for out purposes it will work just fine. None of the newer stuff has been added to it.
Old 01-03-2012, 09:56 PM
WYOSVX's Avatar
Update: Since there can be a lot of talk and no report of any action, thought I'd report that the tranny is now mine, is out of a Saabaru, actually, and only has 21K on it. I expect to have the swap done by the seller, who showed me his swap in his personal SVX and it's nicely fabbed and feels right for my tastes.
Took my SVX for my first long road trip- about 12 hours. It really is heaven on the interstate. Good thing for me that Montana has a speed limit again.
I'll report with pics when/if this all works out. Thanks, again, for the advice.
Old 01-04-2012, 05:22 AM
That will be the first Saab A ru tranny I have heard of . Congrats . Did u drive his ?Is his also a Saab?
Old 01-04-2012, 07:00 AM
WYOSVX's Avatar
It's the Saab 9 - 2. It is a Subaru with Saab trim on it- very few changes. You probably know that, though. The tranny is a Subaru tranny, just has the Saab name on the car. I did drive his 5-speed and it was an older 5-speed and I liked it but don't think it came from a Saab. The one in the Saab is the '05 WRX that we talked about, so stronger. I could have driven the Saab but had little time so may learn a hard lesson about trusting people. I trusted him completely by our conversations and he has about a dozen SVXs and a Subaru repair shop.
Old 01-04-2012, 01:19 PM
So he will do the conversion also? Sent u a PM
Old 01-04-2012, 03:52 PM
WYOSVX's Avatar
Yes, he'll do it. PM'd back.
