Old 10-26-2011, 02:04 PM
THE NEW GUY THE NEW GUY is offline
hesitation when pressing gas pedal
Hi everybody. My SVX shows some hesitation when I press the gas pedal to change lane and pass somebody. This hesitation last 2 or 3 secs, after that, car pushes hard and show all the torque. Do yo think temperature going down may affect? Any ideas anybody? No CL. New air filter (K&N): no change.
Old 10-26-2011, 07:29 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: hesitation when pressing gas pedal
Try cleaning the mass airflow sensor and getting on oem air filter.
Wanted: Steering Wheel
Old 10-28-2011, 08:05 PM
news about this issue:
I´ve just verify that the hesitation is just until rpm´s get 2500rpm. from that point, the car push really hard. I suspect this is because of the firing advance.
Old 10-28-2011, 08:19 PM
IS it a 92? It could be that it needs the old bead crush mode.
http://www.subaru-svx.net/forum/show...ght=bead+crush
Old 10-29-2011, 05:53 AM
michael's Avatar
What Potholes ???
Check for ECU Codes too.
http://www.svx-iw.com/svxiw/article/...php?article=78
btw: did anyone notice the first sentence in this doc? hint, transmission.
Old 10-29-2011, 04:06 PM
I have no CEL on.
What is it "the old bead crush mode"?
Old 10-29-2011, 05:35 PM
There is a noise suppression bead on the ECU circuit board. The SVX had a hesitation issue when it was first sold, and the factory fix was to take a pair of pliers and crush that little bead. There's a thread on it, and a How-To page.
michael's Avatar
What Potholes ???
Sean posted a link ^^^^
Old 10-29-2011, 07:00 PM
I have no CEL on.
Sorry that was supposed to read "mod" not mode. Damn smart phone.
Old 10-29-2011, 08:31 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
it doesn't seem a problem they way you say it...mine is kinda the same
when you step on it in 4th, it can't push that hard so it waits to make sure you wanna go fast then downshifts and you'll be gone...process takes 1-2 secs!
it's just the way most automatics are...
again it might not be this but mine "hesitates" too!
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 10-29-2011, 11:02 PM
to David 12121: theres no kick down in the process... I´m in Power mode all the time. This hesitation is present in every gear but its more noticeable at 3rd or 4th or when cold, when you can feel almost three steps of torque improve before reaching the 2500rpm point, where it really pulls. When hot, only the 2500rpm piont is really noticeable. I would say its mapped on the chip...
to crazy pilot: so I have to remove the ECU, identify one resistor and crush it with a plier? is it the bead crush about? So I dont need to change the chip?
Old 10-30-2011, 05:58 AM
michael's Avatar
What Potholes ???
Did you check to see if you have old codes stored? Sounds like you may have a sensor on it's way out.
Old 10-30-2011, 07:16 PM
I did not have time to check stored codes but I did remove the throtle body and clean it deeply. bypass valve too. Control of iddle speed is way better now... but still hesitate. I've discard relations between hesitation and induction valve by confirming the operation of the induction valve in different moments of the hesitation. (vacuum meter connected to the induction solenoid). By the way, I've got to say that the induction valve does not activate the iris at speeds over 4200rpm's. As a matter of fact, the induction solenoid was activated only when the torque of the engine is very required at low rpms and stay on until you release the gas pedal or the engine reaches the exigency level demanded by the gas pedal. Tomorrow, I'll read stored codes and try to replace the O2 sensors.
Old 10-30-2011, 08:35 PM
The valve between the two halves is normally open, to close at 2200 rpms to form the Inertia system. This systems torque peaks at 3200 till at 4200 the valve opens to join the two halves together, to allow the Resonate system to take over, peaking the torque at 4800.
This system won't cause your problem.
Old 11-01-2011, 07:47 AM
Ok guys. I should check stored codes before posting this.
I have the following codes:
32: copilot's O2 sensor
37: pilot's O2 sensor
28: pilot's knock sensor (but is new, bought in amazon))
14: injector 1
56: EGR valve (but I just replace the EGR plastic pneumatic valve and disassemble and clean all the system, and replace all the vacuum hoses)
23: MAF abnormal voltage
I'll change the O2 sensors this week... then I'll let you know.
