timing belt help
This is my first timing belt.
this belt is about a week old and the timing marks are gone off of the belt. I need to take off this belt but I am worried about getting it back on properly without the marks on the belt. Anyone offer me some pointers and help? |
Re: timing belt help
http://www.subaru-svx.net/forum/showthread.php?t=58151 I also posted this link http://phantomotaku.com/SVX/ there's some good manuals there
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . |
The belt mark doesn't matter the pulley marks mater. I would not trust belt marks.
There are 3 marks on the belt... the Center Crank pulley...and one for each of the Cam pulleys. They must line up with the marks on the Cam pulley and on the crank pulley http://www.phantomotaku.com/SVX/MSA5TCD95S_8_Engine.pdf
Mitch Hansen
I was going to post the images from my photo locker... but the embedding seems to be borked....
http://www.subaru-svx.net/photopost/...e=2&ppuser=447 the marks on the belt should line up with the marks on the covers and pulleys so that there are the correct number of teeth between. I think it's 53 to the right and 53 to the left from the center...but that's from memory... the PDF I linked above states the correct numbers in the Engine Timing belt section about half way in.
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . Last edited by Uncamitzi; 10-15-2011 at 01:40 PM. |
ConnSVX is right, the marks on the timing belt don't matter. You can use them when you install the belt for the first time but after that they shift about one tooth per crankshaft rotation. However, the marks that really matter stay aligned (if you did everything right).
92 Pearl White LS-L 215,000 KM smallcar 5MT, Ecutune 1.5, SS brake lines, svxfiles 6000K HIDs, $15/15 min mod, $20/20 min mod, Front and Rear Energy Swaybar Bushings, Bosch Relay Mod 92 Liquid Silver LS-L 127,000 KM |
The count is 53 teeth from center pulley to each mark on the cam pulleys. That should not change
Mitch Hansen
If you shut off the motor and you touch nothing you could line up the marks. ME and this is just me , I would line up the mechanical marks (pulley to ref marks on the block) timing is timing mistakes are made when you line up just the belt
I'm not trying to get in a pissing match here with you CONN.... I'm trying to give help to someone that said they haven't done this before.... I did it myself for the first time and I'm trying to help someone from that point of view.... Not someone like you who has done it a million times....
Mitch Hansen
I hope that ths helps;
http://www.subaru-svx.net/photos/use...svxfiles|34160
Unbolt the bottom "center" timing belt idler pulley and put the pulley and the bolt in a place where you can easily find them to put them back on later. Now, you can actually just lay the timing belt in the place... at all the correct positions, exactly where it is supposed to be!. The tensioner must be bolted in place compressed, and remain compressed with its pin in place. leave the pin there for now. Next, simply locate the roller pulley that you just took off a couple of minutes ago, bolt it back on, and torque the bolt properly. The belt will be just snug now, with the idler pully back in place, and the timing belt will remain in the correct position. (if you "laid it on" correctly) Now and only now, "pull the pin" on the tensioner. OK, it's OK! "PULL THE PIN" This actually works like a champ. Now, say "thank you" and go to bed! Keith Last edited by kwren; 10-15-2011 at 11:59 PM. |
For your first time it will be easier if you have marks to line up AS WELL as the marks between the pulleys and the engine. Another tip is to use a clothes pin or spring clip to hold the belt to the cam wheels while you're positioning the belt around the rest of the pulleys.
Bump for anyone who needs the hep..
I was about to punch myself trying to get it all in place together. "Pin".... Red Text Below {I actually had to put the tensioner in a vice to close it} Quote:
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles Last edited by ShiuludeSVX; 10-25-2013 at 04:25 AM. Reason: Emphasis |
