Old 09-21-2011, 10:26 PM
Dessertrunner's Avatar
Controling the injectors
Hi all,
Can anyone tell me if there is any thing special about the power to the injectors. I want to make a test bench is it just a matter of supplying 12V to the head of the injector or do I need to do something more.
Tony
Old 09-22-2011, 10:48 AM
Re: Controling the injectors
Its a pulse timed in ms
Old 09-22-2011, 11:09 AM
when i test injectors on the bench i jump power to the power side from a battery and then hook the negative side of the battery to a file. use a jumper between the file and injector signal. use a needle or something sharp and run the jumper across the ridges on the file. this will create pulses to make them spray. the faster you run it the shorter each pulse is. definitely redneck mechanics but it works.
Old 09-22-2011, 05:22 PM
The injectors are 12 ohm, no dropping resistors, so they can be supplied with 12V. Just pulse the ground side.
Old 09-23-2011, 04:42 AM
Thanks guys there are good suggestions and putting me in the right direction.
Tony
Old 09-23-2011, 09:37 AM
I thought that either the ground or positive could be pulsed, which one was most convenient.
Old 09-23-2011, 11:40 AM
you can pulse either side but it's best to mimic the setup in the car as closely as possible if you are doing more than making sure that they just click.
Old 09-23-2011, 09:48 PM
kwren's Avatar
kwren kwren is offline
I have to go with John on this one... I don't think there is any difference in the results... none!
Keith
