Old 09-19-2011, 08:34 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Just had tranny rebuilt, and .......
Just picked up my 97 ebony from the tranny shop, and had the original tranny rebuilt. The tranny shifts great, but when making turns from street to street, and turning while reversing it has a slight bind and makes a thumping noise from the rear end. The shop said all the AWD parts are brand new, as are the clutches and replaced all the solenoids. Also my speedo and odometer dont work most of the time, and when the speedo works, the needle bonces from 20 to 0. I guess the speed sensor is either no good or not on all the way I notified the shop and they said to bring it back so they could look at it. Any idea on what the problem may be. I just shelled out $1,877 for the rebuild tax included.
1995 POLO LSI 76K MILES SOLD
Old 09-19-2011, 09:20 PM
ZMan's Avatar
ZMan ZMan is offline
Re: Just had tranny rebuilt, and .......
Add 3-4 ounces of a Limited Slip Friction Modifier to the tranny fluid and do some slow almost full lock circles in each direction.
A trans shop near me had to do this after replacing the clutch pack TWICE on a customers car. - That fixed it.
Here's the oil they used:
http://www.redlineoil.com/product.aspx?pid=41&pcid=4
Old 09-19-2011, 11:40 PM
Green1995SVX's Avatar
I would not add the limited slip additive. That is a band-aid. If the transmission were properly rebuilt, it should not be binding. When I had the transmission rebuilt in my 95, I experienced the same problem. The eventually had to rebuild it a second time using genuine subaru transfer clutches, and that solved the problem.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 09-20-2011, 07:11 AM
ZMan's Avatar
It is not a band aid. I've heard this before from a number of arm chair mechanics who THINK they know what's going on.
Fact is, the shop I was talking about was using Subaru clutches, and even soaked the second set for 2 days in some kind of fluid to condition them.
When that didn't work, he found that even Subaru themselves do this.
It never hurts the tranny and it's not a band aid.
Ford, GM, and so on use this fluid in their posi traction rear ends - are they using a band aid?
Where did you get your info from?
Old 09-20-2011, 08:11 AM
In difficult times like these, I have to wonder , "What would YT do?".
Old 09-20-2011, 08:32 AM
Not sure??? But he'd be done by now.
Old 09-20-2011, 10:23 AM
Comparing GM and Ford rear ends to a Subaru transfer clutch...
Old 09-20-2011, 10:27 AM
ZMan's Avatar
Yeah, you missed the point.
What part of Subaru themselves use this same method
didn't you get?
Do you have anything constructive to add?
Old 09-20-2011, 10:58 AM
didn't you get?
A proper rebuild shouldn't need anything other than a proper transmission fluid. Worst case, do some figure 8's to break the transfer clutches in but I would not add any type of additive.
Old 09-20-2011, 11:37 AM
SVX92-97's Avatar
Guess, I better start doing figure 8's. How many should I do
Old 09-20-2011, 11:43 AM
dcarrb dcarrb is offline
As svxfiles suggested in your other thread, the TPS may need adjusting or replacing. Maybe you didn't notice before because the transmission was shot. A new TPS completely cured AWD binding and gear-hunting in one of mine.
dcb
Old 09-20-2011, 11:53 AM
SVX92-97's Avatar
how much is new TPS?
Old 09-20-2011, 12:00 PM
SVX92-97's Avatar
Just called my local subaru dealer. List is $289, my price would be $207 plus tax for a new TPS. I guess I should try adjusting the current one first.
Old 09-20-2011, 12:32 PM
when i had my tranny rebuilt the shop said that the ultimate cause of death for the transmission was a bad speed sensor. since the trans was confused it was trying to apply the transfer clutches all of the time. don't know if this is true or not but since your speedo doesn't work maybe it's worth looking into.
Old 09-20-2011, 03:12 PM
ZMan's Avatar
Based on what?
