Sea Foam?
Just wonder has anyone used Sea Foam on their SVX engine and gas tank? How is this thing doing with SVX's?
-SSSVX 92 LS-L TEAL since Aug '01 92 LS-L YELLOW since Mar '05 |
Just do a search and got some answers. Shld've done it first...
But the Sea Foam only works with engine oil and gas? Could we use sea foam in the tranny fluid, power steering fluid and radiator?
Sea foam has a tranny can....Different can!
Greg |
sea foam is god. ran that **** thru my sr20 right after i installed the thing. it had a bit of valve ticking before, went right away. annoying to do, but works well.
you can get diffrent results i have people come in all time time with a tick in the engine and every time they ask for it to be sea foamed instead of diainosed and repaired it never works
- John ASE certified Master Tech W/ X1 Twin City Fleet repair, St. Paul, MN need work done? Have tools will travel
I watched a guy 'Sea Foam' his XT6 right before he competed in an autocross. Now I'm too scared of the stuff to even look into what it's supposed to do.
I use seafoam in the same fashion as GM Top End Cleaner... good stuff.
1995 Subaru SVX -Accel Green Filter * -Flowmaster Exhaust -ECU Stage 1 Chip * -Alluminum Drive Pulley * -Stage 1 Shift Kit -Small Car Clear Lenses and Corners -1997 SVX Grill -17" X 7" Enkei Shoguns *Thanks Dayle! (SVX Motorsports) 1987 Pontiac Formula 350 -Enough (Once I put it back together again) |
Something tells me you're about to say you met the guy at the Dragon or something similar.
I used sea foam in my car..fixed my O2 sensor check engine light . I recommend it..
I've always had good results. It gets my recommendation.
Mike |
Perhaps, in order to get a good result also has to use it properly.
I asked this was thinking of making my yellow svx engine running better. It doesn't really have any problem...just thinking if I could clean the engine inside and make it run better, why not. But I'm gonna try the sea foam on my mx-3 V6 on the next oil change...on the mx-3 forum, the sea foam has like more than 95% success rate to make the V6 runs better and quieter.
Is there a How-To for SeaFoam on the SVX lying anywhere?
Thread Tools | |
Display Modes | |
