Old 02-22-2006, 02:37 PM
Leaky washer nozzles
Does anyone have a tip or trick for fixing a leaky windshield washer nozzle? I adjusted the squirt pattern on the pearlie last night and after the washers stopped squirting a few drop of fluid continued to come from the nozzle, putting blue fluid on the pearl hood.
My 96 doesn't have this problem. I thought someone here posted something about forming a loop in the washer tubing before it entered the nozzle. I think this somehow did something physically to the pressure within the system
Old 02-22-2006, 04:08 PM
Here's an idea...put the nozzles from the 96 on the pearlie
Old 02-22-2006, 10:31 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
If you change the seals on the washer nozzles, will they solve the leaking? Or what if you change a set of new washer nozzles? Make sure you don't forget to check if the rear washer nozzle is leaky?
I'm sure the pearl white's even better in your hands.
PS: Don't use "blue" fluid, blue one tends to leak...
PSS: What was the cause of the battery dead problems? Maybe I missed the post.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
