Old 10-23-2005, 05:06 PM
SubaSteevo's Avatar
No longer blue member
No sound - aftermarket radio
While driving, my CD player stopped making sound and the antenna went down, but the unit remained on. Turned it off then on again, antenna went up then right back down, still no sound from CD or radio. I'm thinking a blown fuse, any ideas?
-Steve
01' MSM Lexus IS300
Old 10-23-2005, 05:26 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Seems odd that the antenna went down. I would definitely check the fuses and also check for a shorting wire. I'm assuming you used svxdc's harness?
Did you heat shrink the wire splicing or did you use electrical tape?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-23-2005, 10:02 PM
kuoh kuoh is offline
Are you running off the internal or an external amp? If the radio's ACC inline fuse were blown, then it won't turn on at all. If the B+ fuse were blown, then it won't keep time or memory settings. If the remote turn on fuse were blown, then the antenna wouldn't go up at all. I'd guess the radio has suffered an internal fault and has shutdown. How loud were you playing it when it shut down?
KuoH
