Old 10-24-2005, 06:00 PM
kuoh kuoh is offline
I think the sunroof drains down the B pillars, so I doubt that water is causing any shorts around the dash area or the ECU. It sounds like the ACC wire is shutting off like it's supposed, but not the IGN wire. Like I said, get under the steering column and try disconnecting the ignition harness next time. If the car dies immediately, then you know the problem is with the ignition switch.
KuoH
Old 10-24-2005, 06:03 PM
Look here.
KuoH
Originally Posted by mhl0125
What do I have to remove to get to the bolt holding the ignition switch in place?
Old 10-24-2005, 06:11 PM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Thanks. Great pictures and description of how to do it. I will probably not be able to tackle it until the weekend.
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 10-27-2005, 11:06 AM
Actually it has 4 drains...1 in each "A" pillar and 1 in each "B" pillar. When I checked mine I had 2 of the 4 drain hoses out of place (not draining outside the car). It's actually the reason for the rust on one panel.
Old 10-27-2005, 11:38 AM
Where do I look to find the drains and hoses?
Michael
Two-owner:169K
2008 Toyota Prius
Old 10-27-2005, 06:07 PM
The front ones are behind the kick panels (behind all the wiring).
The rear ones are in the trunk behind the side panels.
Old 10-27-2005, 06:53 PM
oab_au oab_au is online now
Just guessing.
If there is water on the floor, it may be shorting the ABS comp, that is under the seat. This may be feeding the power back into the ign circuit?
