Where is a good place near driver's seat to ground?
i want to install power mode mod over my thanksgiving break, and i need a good spot to ground that lonely pin #4. i already tried it by switching pin #6 with #4 so i could control it via the manual mode button. it worked well, but i missed manual mode, especially in traffic. i've seen the posts on grounding it to that blue wire by the kick panel, but i feel like i'll break something by slicing wires, or slice the wrong one... so, other than the door, are there any other places i could use for ground (without removing the whole radio cage)? i thought about the parking brake handle, but wasn't sure.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: Where is a good place near driver's seat to ground?
Your putting a switch near the center console??
- Any of the screws holding the shifter base to the tunnel. - Bolts holding the ebrake handle down Or put a DPST stitch between the manual button and the ECU, one pole will go to pin 4, the other pole to pin 6. Throw the switch one direction and the manual button does Manual, throw it the other and the manual button will do Power.
when i had one (before the new tcu) i used the tcu bracket bolt for ground. worked well.
On for the Manual control and one for the power antenna. In fact, the button of the side of the gear selector lets you choose between ECON (normal) and POWER. .
That is hella cool. |
want.
