Legacy-fixed timing belt now what
Ok So I replaced the timing belt per requirements and now my car wont idle when it warms up, it idles fine with no missing when its cold but as soon as the thermostat opens up thats when it dies and wont stay running unless I keep in the gas.I also replaced the FPR as I thought this was my original problem. All spark plugs are firing and are dry, no oil or fuel but a couple of them are black and sooty not white. Any suggestions would be helpful
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT |
Same motor and FPR but the plugs are sooty on that side so what can you tell me?
It could be the coolant temperature sensor since it happens after it warms up.
Replace the Coolant Temp Sensor. It'll fix your problem.
Ill try the coolant sensor next. Thanks for the quick responses
Hopefully the timing belt was aligned correctly and didn't jump a tooth.
Im starting to think that Ive jumped one tooth on the timing. Ive changed the coolant sensor and nothing changed. Can it being one tooth off affect it that much?
Usually no but who says it's just one tooth?
I hope its the right timing belt Advanced auto parts you know
