Old 02-13-2006, 11:13 AM
SubyLuver SubyLuver is offline
Loyal Subie-ist
Send a message via MSN to SubyLuver
Rear Diff Problems?
How to explain it..... If I am gasing the car on snowy roads the tires will slip for a bit then a jerk from the rear end hits and more power goes to the back, is this a rear diff mount or does the rear diff have problems itself?
Symptoms to look for?
Subyluver
'92 Subaru SVX Ebony 216k miles
(Magnaflow Custom Cat-Back, ES Stablizer Bushings, Permacool Relocator, 2.5RS FPR, SS Brake Lines, EBC Green Pads, Raceconcepts D/S Rotors, Pirelli P-Zero Nero M&S)
(To-do list Koni Struts & Springs lacking funds)
Old 02-13-2006, 03:33 PM
oab_au oab_au is offline
The symptoms suggest that the Transfer valve is sticking. The fix is to replace the C Solenoid/transfer valve assemble, and clutch plates, in the rear section of the transmission.
If it is not fixed, damage can be caused to the front differential, or the AWD clutch hub.
One Arm Bloke.
Tell it like it is!
Old 02-13-2006, 04:01 PM
Earthworm's Avatar
Meow!
He's right. My tranny started doing that but the high clutch failed before any of the failures he mentioned happened.
Old 02-14-2006, 08:45 AM
Loyal Subie-ist
Is this something that requires a tranny overhaul to replace? Solenoid C? Isnt that inside the tranny? I am wondering if it would be cheaper to let the tranny go and pay for a 5mt instead?
Subyluver
Old 02-14-2006, 10:03 AM
Solinoid "c" and the transfer clutches are in the tail housing of the tranny, and can be replaced with the tranny in the car...just have to remove the exhaust, tranny crossmember, and drive shaft to remove the tail housing to get at them.
Old 02-15-2006, 08:06 AM
Loyal Subie-ist
I assume the parts are listed on this page, but I do not know what parts to look for, some direction would help and also help me figure which limb my mechanic is going to take(since I am low on cash)
http://www.subaruparts.com/diag/?mod...category=170-A
Any other direction to parts would be a nice help, I've noticed 1stsubaru has a little bit better pricing too so I will check there once I figure out what I need.
Oh yeah, BTW my Tranny code is 11 but I think that is because of the smallcar kit that I have installed?
Subyluver
Old 02-15-2006, 08:14 AM
DarknessofDeath's Avatar
DarknessofDeath DarknessofDeath is offline
Inhabitant of Darkness
tranny code 11
i'm sure that was mentioned in another thread on the Q and A.
i recall the answer being too much resistance with the small car and the stock resistor combined ~
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 02-15-2006, 08:21 AM
The Transfer clutches are #1 (metal plates) and #2 (Friction plates) in that diagram, but the "C" solinoid is not in that diagram....
The C-Solinoid is # 9 in this diagram
Diagram
Old 02-15-2006, 08:37 AM
Loyal Subie-ist
Diagram
Is this something a Wanna-be Mechanic is ok to attempt? hehe I can do brakes and various other things but the most I have done to my tranny is replaced the internal filter
Subyluver
Old 02-15-2006, 08:40 AM
It's pretty straight forward.....just like changing the clutches on a dirt bike...
Old 02-15-2006, 08:51 AM
Loyal Subie-ist
If anyone has a tech manual and could scan a couple pages of how to on this that would be great, I am not sure a Haynes will cover this technical of a job. Or if anyone knows where I could obtain a how to on it that would be great.
Subyluver
Old 02-19-2006, 07:49 AM
Loyal Subie-ist
In this part of the transmission, should I expect a bunch of tranny fluid to drop? any other things to watch out for while doing this job?
Subyluver
Old 02-19-2006, 09:44 PM
intelisevil's Avatar
intelisevil intelisevil is offline
<<<Alcyone
Are there any other items you would suggest replacing while it's open?
How about item #3? It comes in various thicknesses (3.3mm, 3.7mm, 4.1mm, 4.5mm), how would we know if the one we have is the correct thickness for the new plates?
Has anyone done a "How-To" on this? I searched but couldn't find one. Suggested parts list including gaskets, muffler pipe bolts, etc. and bloody dissection pictures would be a good thing to have. Pictures to scare off those of us who are almost willing to try it, but recognize our limits. Parts list so we can buy all of the needed parts to take down to our local trusted mechanic to make the repair for us.
Thanks, Dan
Old 02-21-2006, 01:53 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Send a message via Yahoo to SVX-FF
Hey Subyluver,
Give me a PM and I can show you how to do it. I have done one. It takes about 4 to 5 hours. The tranny fluid drains forever.
It is not that hard. I actually have a rear section off of a tranny if you want I can take some pics for you.
Steve
92 SVX AWD 130,000 w/ rebuilt SVX 4.11
97 Audi A4 1.8T (Daily Driver)
03 Ford Expedition(hers)
SVXepidia SVX information warehouse
Are you in?
My Old Locker
A 4.11 Founding Father
"Tranny #6" I really need a manual
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
