aluminum drive shaft
so my driveshaft is F'ed
i need a new one so i'm going to go ahead and get one made (w/ greasable u-joints) i got a rough estimate (over the phone without any real information about leangth and so on) of $600 is that good/ bad? (i was quoted approx 600+ to replace the stock one) also does anyone here run a custom driveshaft? pros/cons? thanks |
Are they going to balance it or test it too for that price? You wouldn't want whip to occur while driving
I think the owners that have manual transmissions have had to get longer or shorter shafts.....As for stock, I'm not sure. |
If you are looking for weight savings and have the extra money, go for it, otherwise try to get yours rebuilt. It will be cheaper. Doug
money really isn't an issue (but i don't want to get ripped off)
the weight savings would be nice but isn't really a priority would getting it rebuilt be relliable? would an aluminum one? |
Get a carbon fiber driveshaft. That way, if it ever breaks, it won't take the bottom of your car out along with it.
Its unlikely that you'll be able to get a one-piece aluminum driveshaft to be vibration-free. The SVX driveline angles are not set up for a one-piece driveshaft. I think mohrd's advice about rebuilding or buying a new one is good. An OEM SVX driveshaft can last at least 100k miles. Probably longer than you'll keep the car. If you go with a new OEM driveshaft, get the early model one. Its got a better quality center joint than the late model ones.
Jaya,
I have a SVX driveshaft you can have for $50 if you want to come pick it up...
