Aftermarket horn wiring
I am considering replacing my stock horns with the Stebel TM Magnum 80 electromagnetic horns. They are rated at 139db. The website is here with an available sound clip:
http://www.stebel.it/stebel/index.htm (Click the products link, then the electromagnetic link, then the TM80 Magnum link) Anyway here is my question: Since our stock system already has a horn relay in the circuit, can I just use the existing wiring to connect to the + terminal of the horns and run wires to ground from the - terminal on the horns? Or do I need an additional relay? The horns are rated at less than 12A. The horn and brake circuit in the SVX is fused at 20A. Should I add an additional inline fuse? According to the FSM, our horn switch provides the ground when depressed. Any help is appreciated. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-19-2006 at 03:40 PM. |
did i read that right? 24 volts?
I read 12A@24V. Wouldn't that mean 6A@12V for the pair?
139db is at only 4" from the horn
I had a tech at my favorite stereo shop measure the sound pressure of the stock SVX horn at 6" from the horn, using a db meter. It measured 97db. That being said, remember that the decibel scale is logarithmic and therefore the sound pressure doubles for every increase of 3 points, i.e. a horn with 115 dB is approximately six times as loud as a stock 97db SVX horn. .
I understand how db works. I just find it silly to measure it at 4". Most db readings I see are at 1 meter from the source.
But a sharp guy like you should be able to answer my original questions.
And if the stock SVX horns measure 97db at 6" (with the hood open), what is the sound measurement at 1 meter with the hood closed? In any case, these have got to be louder than what I have. They measure 3.3" x 3.5" x 3.5" each. And they can be gotten for only $18.95/pr., plus shipping, from HornsPlus http://www.hornsplusauto.com./ .
The horns as a pair are rated, 12 amps at 12 volts and 6 amps at 24 volts, not an excessive current drain and in line with OEM.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 06-19-2006 at 11:39 PM. |
Yes I agree that the specification is rather confusing but again examine the way things are set out. The horns sold for 24 volt operation will most definitely have a winding of twice the resistance. The power required i.e. watts will be the same for 12 V and 24 V. When the voltage is doubled the current is halved to provide the same power requirement (watts).
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 06-20-2006 at 05:57 PM. |
Yes for power to remain the same if you double the voltage you must half the current.
I was running the assumption the same model was used for both 12V and 24V operation. 1 more thing I will point out though, if you double the voltage and half the current you must quadrouple (not double) the resistance.
