  #121
Old 10-23-2012, 12:57 PM
BackWoodsBob BackWoodsBob is offline
Re: Twin Turbo EG33 Build - cozykat
you know what they say, excuses are like ass-holes, everyone has one and they all stink!
Old 02-18-2014, 10:05 AM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Well, I've been quiet but my new years resolution was to get this baby done. So I have been working on one aspect or another of my project for the last few weeks.
I started setting up to install accessories and then decided that I since I've dragged it out this long, I might as well clean this engine up along with the hard lines. (If anyone is curious, for this process I used KBS Coatings product line: AquaClean (Degreaser/Paint prep), Rust Blaster (& etcher), Rust Seal Primer, BlackTop Chassis paint, and MotorCoater)
engine before:
engine after:
Last friday a bunch of bolts I was waiting on arrived so I'm FINALLY moving forward with assembly:
misc parts:
(get this iris o-ring from OT)
This will either be a good looking engine or the prettiest coffee table ever.. I'm ok with that.
Also, I just acquired STeeL25T's Hydra EMS so I need to tinker with it to figure out how it works.
Marisa
Old 02-18-2014, 11:45 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Marisa,
Outstanding documentation! Will you be fabricating brackets to hold the turbos? Any porting to the heads and intake/stacks prior to painting?
Cheers,
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-18-2014, 06:24 PM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Cleanest engine I've ever seen O_O
Old 02-19-2014, 09:20 AM
cozykat's Avatar
Originally Posted by SVXRide View Post
Marisa,
Cheers,
Bill
Thanks Bill!
I'm sending my intake manifold to GrimmSpeed to get it PnP (Thanks to Matt's autocross GS sponsorship winnings, it's not costing much out of pocket). The only down side is that they have a 5 week lead time - and was hoping to have this done by Reading. The intake manifold is all sorts of squirrelly inside but the intake stacks look okay to me so I'll leave them alone. I plan on getting the exhaust manifolds PnP sometime later. I'm currently spending money on new hoses and bolts - which seem like a small cost but altogether added up to over $500 even with discounts. I said "I'll order any hose that looks like a L or S from Subaru" which apparently applies to every hose under the intake!
I've also been spending time searching through storage bins because I've hidden away new parts over the years which I can use now.
Thanks Jonathan! It took me a long time to clean all the sections and misc parts.
My garage floor is littered with cleaners, paint, and parts.. It looks like several SVXs blew up in there..
Marisa
Old 02-19-2014, 06:34 PM
Scoobyru's Avatar
Scoobyru Scoobyru is offline
engine before:
engine after:
misc parts:
Curious to see what this ends up putting down for power. very interested...
1992 Dark Teal LS-L 237k #103994 (Sold)
GC8 Nardi Steering Wheel/
Crossed Drilled Rotors/
18" Exel Evo Wheels/15min Mod/
6k HIDs/ECU Crush Mod/
Power Mode Mod
1997 Brilliant Red LSI 151k #100109
PWR AU Radiator, Stebro Catback, Hella Supertones, SS Brake Lines, Cross Drilled Rotors, QC, Power Mode Mod, SSR GT3 Wheels 18x8 et35
1997 Ebony Mica LSi 177k #100321
Old 03-17-2014, 09:06 AM
cozykat's Avatar
Turtle update:
Just waiting for my collector & intake manifolds to return and preparing the next parts to install (seems I have about 10 small parts I still need to order). I shifted my attention on the Foz this past weekend but I plan on installing the Hydra ems in the SVX tonight - keeping fingers crossed nothing makes a fizzle sound. Also think I found a tuner for it once everything comes together.
Then my next SVX tasks will be replacing bulbs (my dash lights decided to go out), swapping trunks and fitting/installing the JDM wing, replica bumper, and side skirts. Once the engine is done and verified running, I'll be pulling it back out momentarily to get the engine bay re-sprayed and the whole car repainted. The last clear coat was applied poorly and after they "fixed it" with a polishing -> it's all but flown away with the wind as the polishing revealed all the pinholes in the clear. In anticipation of the paint job, I've already purchased most of the door/window weatherstripping and seals - just need the rear windows/windshield.
p.s. If anyone is going to the autocross event in Blytheville, Arkansas this weekend - see you there! Matt will be driving his BRZ.
p.p.s. I can't believe it's late-March already.. WTH!
Marisa
Old 03-17-2014, 11:12 AM
SVXRide's Avatar
Marisa,
A strong suggestion is to buy at least one (perhaps 2) AEM widebands and get them installed now all the way up to the point of screwing in their sensors (which means you'll need to figure out where to weld in the bungs for the sensors). This is the only way you'll get a really accurate tune - even more important when you install the turbos!
Great to see everything coming together!!
Bill
Old 03-17-2014, 11:30 AM
Tireiron Tireiron is offline
Instead of AEM widebands, I would recommend running the wideband O2 for the Hydra. The integrated wideband will make tuning that much easier.
Old 03-17-2014, 02:26 PM
SVXRide's Avatar
Tireiron,
I agree, with the caveat that the Hydra widebands are considerably more expensive than AEM units....
Cheers,
Bill
Old 03-17-2014, 06:46 PM
cozykat's Avatar
Thanks guys!
The Hydra, from STeeL25T, came with the wideband kit so it maybe all I need.
I'm currently trying to remember if there is anything special to removing the suede piece under the steering wheel.
Marisa
Old 03-17-2014, 10:18 PM
Gamesy's Avatar
Gamesy Gamesy is offline
There's a screw on the backside you'll need to go from underneath
Old 03-18-2014, 06:15 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Make sure that the MAP hose doesn't get crimped or bent backward on itself when you mount the Hydra! With the limited space under there, it can be challenging to avoid.
Old 03-18-2014, 09:36 PM
cozykat's Avatar
Thanks. It was the screw behind the side view mirror control/parking button that caught me - I knew there was a hidden screw but it was the "where" I couldn't recall. I finally had to admit that my memory isn't so great and went inside to read the manual before I broke anything.
Yup, I'll be sure to watch out for that. I need to buy replacement hose but was thinking about the cramped space while looking behind the dash. Currently, I am just reading through the Hydra documentation and ensuring proper communication between PC to Hydra and Hydra to SVX. (so far so good)
Marisa
Old 08-23-2014, 11:38 PM
Your memory is bad. You should replace it asap.
blk 92' LSL w/ average mods
