  #151
Old 01-21-2015, 01:03 AM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Re: Twin Turbo EG33 Build - cozykat
Originally Posted by SVXRide View Post
Marisa
Could yourself fortunate! Grimmspeed has gotten out of the porting business
No reason given on their website.
Bill
Yes, I heard.
We thought that GS was initially just putting the service on hold as they focused on R&D and producing intercoolers but given their posts in Nasioc, it sounds like they may be done permanently. Shame, they did a beautiful job on the plenum and intake manifolds.
Marisa
Old 01-21-2015, 08:36 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Originally Posted by cozykat View Post
Ultimately, I'd like to make 300 whp (I think that's a reasonable goal with forced induction). However, I'll be driving it na until I can make up my mind on which turbo.
I plan on doing the same with stock internals (unless my head gasket needs doing, then while I'm in there.... ), stage 2 chip, and a single turbo.
Where are you placing each turbo?
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 03-17-2015, 12:17 AM
cozykat's Avatar
Originally Posted by Tireiron View Post
Very interesting seeing as mine only requires Direct Fire and runs great. The SVX is not a waste spark system so it really shouldn't need to run as one. I wonder what your other settings are under Ignition triggers...
I run
Sequencer = 3
Timing Reference Angle = 68 (need to get a better timing light so i can get this exact around 65 is close)
Trigger Edge = Falling
Sync Edge = Falling
Trigger Type = Generic 12 tooth
Sync Type = Generic 12/24 tooth
Cylinders = 6
I meant to comment on this sooner.
So, "funny" story...
After some stressful hours, we finally learned two things about the 2.7 base map: 1.) the sequencer value [my default] was 16 and 2.) timing reference angle [my default] was 90. Both, as I understand, are wrong.
We caught the timing ref angle a few weeks back and changed it to 65 but missed the sequencer value. Per Hydra's manual: "Sequencer indicates which tooth on the cam signal the trigger will key on. This setting is defined as part of a trigger setup for a specific motor and should not be modified unless you are directed to by your Hydra EMS dealer" - so I felt pretty special.
Also having to check waste spark to start the vehicle made no sense to us either (and I really don't like when things don't make sense).. so after updating the sequencer setting, we unchecked the waste spark - and finally the car doesn't die.
So now my settings are similar to yours:
Sequencer = 3
Timing Reference Angle = 65 (May be worth noting that Kirill's map has this set to 68 like yours)
Sync Edge = Falling
Trigger Type = Generic 12 tooth (in version 2.6 this setting was 24 - but I noted there are Subaru H6 & Subaru EZ30 options )
Sync Type = Generic 12/24 tooth (in version 2.6 this setting was 24)
Cylinders = 6
AND Waste Spark = UNCHECKED
We are still arguing on turbo placement. I'm told that I'll need to cut into the firewall if I want two turbos.. so I very well may switch to just a single turbo as I won't do that. Currently, I'm just tackling one challenge at a time.
Marisa
Old 03-17-2015, 08:07 AM
longassname's Avatar
Just some dude.
Congratulations, does that hydra have an auto-tune feature to develop its own fuel and timing maps?
Old 03-17-2015, 02:29 PM
Tireiron Tireiron is offline
As far as location for two turbos. Delete the useless ABS, and move the battery to the trunk. This now gives you room forward and out for two turbos. Flip the exhaust manifolds to face forward and run them out and up through the flat body panels, then run two downpipes back past the valve covers and down out the engine bay.
Old 03-18-2015, 10:40 PM
cozykat's Avatar
Thanks! Our understanding is that the auto-tune feature is not what it sounds like. You build a base map how you want it to look and then you enable the "auto-tune" feature to perform long-term fuel trims.
I've thought about this but I don't want to loose my ABS.
Spent yesterday road tuning the SVX. Matt said the Hydra 2.7 is easier to tune/make adjustments with than he anticipated. So today I asked my co-worker for my engine hoist back as it looks like that stock engine is coming out sooner than I thought.
Marisa
Old 03-19-2015, 06:54 AM
Just some dude.
ooooh, so you've set the hydra up with the stock engine to make sure you have it all dialed in before installing your newly built engine....
smart
Old 04-02-2015, 11:02 AM
cozykat's Avatar
smart
Well, I try not to be a complete idiot.
Old engine is coming out this weekend - hopefully without much incident.
Side note: I also pulled out the front/rear seats, steering wheel, and suede pieces to get re-upholstered... Should get it back in two weeks - I'm hoping it all goes well.
Marisa
Old 04-08-2015, 11:05 AM
INVADR's Avatar
INVADR INVADR is offline
Pew Pew!
I like your racy new driver's seat. Looks lightweight and sporty.
Mark S.
1995 LSi, EPM, #1152, 197k(ish) miles, 5-speed
Old 04-08-2015, 05:00 PM
michael's Avatar
michael michael is offline
What Potholes ???
I wonder where they get the names for these swatches
Wanted: Steering Wheel
Old 04-20-2015, 07:38 AM
Beaver is awesome!, kinda like something else you said a while back that is awesome also. lol Get your mind out of the gutter girl.
p.s. give me my motor back!!!! how many years has it been now?
FTHNIC
blk 92' LSL w/ average mods
Old 04-20-2015, 10:10 AM
dbarnblatt's Avatar
So impressed with the whole project. Very refreshing to see it done right.
Are you going to loose the auto belts? Seems like a good opportunity to install a set of standard belts from a 1995 or later.
Old 05-11-2015, 01:03 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Marisa,
It has been a little over a month since your last post in this thread. Hopefully you have your interior back, and looking better than new! How is the build going?
-Sam
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 05-11-2015, 10:25 PM
cozykat's Avatar
I think you're confused.
Thanks! For now I am keeping the automatic seat belts but I did acquire a new set of manual seat belts as backup.
Originally Posted by Svx95 View Post
Marisa,
-Sam
Actually, yes! I went with a local custom upholstery guy that does it as a hobby. He did above what I was expecting (because let's face it, I expect a lot) thus I'm literally giddy every time I think about the result. The some photos of the result are below but more photos are in the same folder (and original interior photos can be seen following this link):
Seats:
Suede:
Suede Comparisons:
Concerning the engine progress: The engine bay is pretty much gutted so I can have it resprayed. I have just been trying to decide what to do about my brake lines. If I leave them in, they stick out pretty far and I fear it would impact the quality of the paint work. In production, I'm sure the brake lines were installed with absolutely nothing inside the vehicle, so their removal is a bit of a hassle. I'm trying to develop a plan on how I'll remove and cut the lines (for maintainability).
Marisa
Old 05-12-2015, 09:57 AM
EdWindows's Avatar
That looks great! How much did the seats and suede cost seperately (including materials)? I've thought about getting all the Alcantara paneling redone and re-upholsting the seats myself with a locally-made kit.
Did they also replace the seat foam?
