Old 04-04-2003, 11:19 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
90 Legacy flywheel on SVX?
Does it fit?
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 04-04-2003, 11:54 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: 90 Legacy flywheel on SVX?
Originally posted by elninoalex
Does it fit?
Well, a 91 does. But it won't match your tranny.
Randy Johnson
Mike Davis -- at Reading VI
Old 04-04-2003, 12:17 PM
elninoalex's Avatar
Registered Abuser
Thanks Randy
Actually, its for my 5 spd swap. Flywheels are hard to come by in these parts.
Old 04-04-2003, 12:21 PM
Aredubjay's Avatar
Re: Thanks Randy
Ah. Then it will probably work.
Randy Johnson
Old 04-04-2003, 12:26 PM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
why not get a lightened flywheel, if you need a new one... it'll help performance too
SV What?
Old 04-04-2003, 12:39 PM
elninoalex's Avatar
Registered Abuser
Are you buyin'
There is quite a difference between $60 and $450. I also like the smoother shifts provided by the heavier unit. I haven't driven one with either, so I am just speculating. Any input is very much appreciated.
Old 04-04-2003, 02:22 PM
elninoalex's Avatar
Registered Abuser
Is there any reason not to use a '90 flywheel? Does it take the same clutches as the later ones?
Old 04-04-2003, 06:20 PM
The 90 Flywheel will work fine, I don't think there is any differance in any of the 90-up manual flywheels.
Old 04-04-2003, 06:58 PM
elninoalex's Avatar
Registered Abuser
Well I got one for $50. It weighs about 18 lbs, so maybe there is some differences. I measured the friction surface and it is 225 mm like the others. So maybe I ended up with a light flywheel afterall.
Old 04-04-2003, 06:59 PM
elninoalex's Avatar
Registered Abuser
Oh yeah, and I got all the pp and crank bolts too. Thanks for the tip, Huck.
Old 04-05-2003, 07:31 AM
NomadTW's Avatar
that sounds like a light one.... they're usually in the 25lbs range...
SV What?
Old 04-05-2003, 11:48 AM
Your welcome, that's what I did the write up for...to save others from my mistakes
