door lock wiring question
I am going to install a remote start/keyless gadget on my car. but the main thing I will have a problem with is the wiring for the door locks. In the diagrams I have seen, they mention a timer in the passenger kick panel as pertaining to the "unlock" and the "lock" is in the drivers kick panel.. I have installed one of these on a Lebarron and it was a little tricky until I finely figured out the correct wires to use for the unlock/lock feature,, I know I have to use a relay because of the negative pulse thing they use on the locks.. what I need to find out is where do the wires from the relay go the unlock/lock wires on the car,, If anyone has done this before. please advise as to how the door lock wires are supposed to be hooked up. thanks.
Vernon |
I have not done this. Sorry I can't help. I would suggest that you be careful when you attach wires around the ECU and TCU. I think the add on remote start has caused a few problems on the SVX.
