Old 09-05-2014, 06:17 PM
michael's Avatar
michael michael is offline
What Potholes ???
ABS coming on for no reason
Sometimes when I come to a slow stop by ABS will activate when there is no loss of traction. I also hear a cartoon like spring sound when it comes on, like a "doing" sound. Anyone have any ideas?
Wanted: Steering Wheel
Old 09-05-2014, 08:10 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: ABS coming on for no reason
Check your tone wheel. There may be a break or a crack.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 10-12-2014, 11:41 AM
michael's Avatar
What Potholes ???
I will check for that. I read somewhere online that low brake pads can cause this. Is this true? I just changed these today.
Old 10-13-2014, 01:57 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
WOW!!!
that is super scarey to think you have that much stopping power !!!
Old 10-13-2014, 05:52 AM
michael's Avatar
What Potholes ???
The wear indicators didn't even make a peep. Another week and I would have had a new wear indicator.
Old 10-14-2014, 05:41 AM
Do you have any binding in the rear? When my transfer solenoid was dying and dead, the ABS would engage all the time because of the back wheels dragging. After I replaced it the ABS issue was gone also.
P.S. I just replaced the rear pads on the '97 and they looked just about like yours. They too never made a sound of warning.
Old 10-15-2014, 03:19 PM
Low pads won't cause the abs to kick in. I'll bet it's a cracked/damaged tone wheel.
Old 10-15-2014, 05:27 PM
michael's Avatar
What Potholes ???
I think you're right. It's still doing it
Old 10-16-2014, 06:57 AM
The worst part is if that's the case, the bearing/hub has to be separated to replace one.
Old 10-16-2014, 05:44 PM
Tireiron Tireiron is offline
Just take out the ABS fuse from under the dash and enjoy the way a car is supposed brake. Subaru ABS is horrible anyway.
Old 10-16-2014, 07:03 PM
michael's Avatar
What Potholes ???
It would be easier to replace the whole works, no?
I would, but I have issues with hiding problems
Old 10-17-2014, 05:51 AM
dannmarr's Avatar
I work for my SVX
The hub assembly needs to be removed to access the tone wheel for replacement.
Subaru SVX for fun
Old 10-17-2014, 01:35 PM
wdb wdb is offline
dances with roads
I had this happen to me too.
Are you getting a code? Could be ABS sensor if you are.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 10-23-2014, 04:59 PM
michael's Avatar
What Potholes ???
My LED is flashing 5x, could this just be the sensor? If its the tone ring, I'm just going to grab a whole hub at the junkyard. Seems like an easier DIY. btw it read front Left - Driver side I presume?
Old 10-25-2014, 03:29 PM
michael's Avatar
What Potholes ???
Any idea? Ring or Sensor, Driver or Passenger side? I glanced at the ring today and didn't notice any cracks.
