Old 07-19-2013, 06:31 PM
Ankh599's Avatar
Ankh599 Ankh599 is offline
Hardest Clutch Ever Help!
Got my SVX back, it runs, it's now a 5 speed, but the clutch is hard to press. Has anyone had this problem?
Old 07-19-2013, 08:15 PM
Tireiron Tireiron is offline
Re: Hardest Clutch Ever Help!
What clutch was used in it? Different ones have different pedal pressures based on holding pressure and spring design.
Old 07-19-2013, 08:40 PM
Cable or hydraulic?
Old 07-19-2013, 09:53 PM
Ankh599's Avatar
It's a cable clutch.
Old 07-20-2013, 04:38 AM
It could be a rusty cable, or the cable could be installed in a way that it is bent more than it should.
Old 07-20-2013, 07:46 AM
^^^ exactly, the cable could be too tight of an angle or kinked, or possibly clamped between something. This why I will always go with hydraulic clutches in subarus, the parts are so available and they work so well.
Old 07-21-2013, 05:04 AM
The cableparts are also readily available, and work great if installed properly...and I feel you get more "feel" with the cable being directly linked to the fork....
The cable ones I have done have all work fine with little effort.
So check the routing of the cable, if that's not the issue, get a new cable (Rockauto is a good source)
Old 07-21-2013, 05:49 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Agreed, just love my svx whit your set up.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 07-21-2013, 08:03 PM
Ankh599's Avatar
Thanks guys. I will have my mechanic to rerun the cable through.
