Old 07-11-2013, 12:08 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
Ecu or climate control unit
I've been looking over wiring diagrams enough to make me go cross eyed and I am confident my fan and compressor problem is coming from a faulty ecu or my climate control unit. Does anyone have for dummies version on how to test the ecu for fan and compressor not running. I could not find a Pin out or wiring diagram.
Problem symptoms: AC compressor does not engage and radiator fans do not turn on
I have some more clues that might help me solve this problem.
r134 pressure is good
ac amplifier functions as it should and does not throw codes.
blower and other climate controls work as they should
radiator fans do not turn on automatically when driving
fans do not turn on when auto hi is selected
no check engine light
Fan LH and RH fuse are good and getting power
AC fuse is good and getting power
I can jump the AC relay 7 and turn on my compressor
Relay fan LH2 is getting 13v at the white/ red wire and when I connect the blue/red wire to battery it turn the fan on
relay fan RH2 is getting 13v at the black/ red wire and when I connect the red/white wire to battery it turns the fan on
Relay fan RH1 and LH1 are both receiving 13v at red/white wire
I am suspecting the ECU but I am also thinking it could be the auto amp unit
Is there anything else i should be checking that can narrow my search or rule one of the two things out
[SIGPIC][/SIGPIC]
Old 09-17-2013, 08:30 PM
stiguy's Avatar
stiguy stiguy is offline
Re: Ecu or climate control unit
Bump. I'm having the same problem but my cooling fans will come on to keep the engine cool. But the ac compressor won't come on nor the fan via the ac turning it on.
#1 1994 Ls ebony parts car-rip
#2 1994 L laguna blue - sold
#3 1992 Lsi pearl white - sold
#4 1992 Lsi pearl white -Ate two engines - Rip
#5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree
#6 1992 Lsi custom orange parts car
#7 1992 Lsi green 4.44 swap. Currently for sale
#8 1992 Lsi custom pearl white. Project car... sold
#9 1992 Teal 4.44 swapped... sold
#10 1995 Laguna Blue. Sti 19 wheels,
#11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂
Old 09-17-2013, 08:35 PM
To the OP, did you ever check for error codes? It could be the trinary switch.
Old 09-17-2013, 08:37 PM
Freon in the system/charged?
Old 09-17-2013, 08:40 PM
stiguy's Avatar
Had the system charged. Was leaking thru the trianry switch. Replaced the switch and filled it back up today and still won't work ::
stiguy's Avatar
It gave two codes 00 & 41 but I haven't found what 41 is.
I dont know if it could be the ecu as talked about in this thread.
http://www.subaru-svx.net/forum/show...%2Fc+diagnosis
Old 09-19-2013, 05:57 PM
showoval showoval is offline
Have you swapped the a/c amplifier for another? Mine started doing this when I removed it move some wires from the previous owner. When I put back in, it worked and didn't work, it work in early morning and at night but not during the day. I checked everything like you did, I replaced the unit with another one from a member here and it worked from then on. I just opened the new one up cleaned and swapped the controls since mine looked better.
01- Impreza RS Original Owner
92- SVX LS-L
Old 09-19-2013, 06:32 PM
stiguy's Avatar
No I havevt yet. Gotta try and get my hands on one to test it out
