heat shields Question
has any one tried too put dynomat on there heat shields to reduse the noise or rattle that they make?
Re: heat shields Question
I wouldn't, just because the smell would be appalling after a short while.
I just recently took all of mine off. It's quieter than ever |
dynomat would be a terrible idea, its not meant to handle the heat, heat wrapping would be a much better idea.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
An angle grinder works better
I went a little more ghetto, vice grips and a 10mm socket
Am I the only one who thinks that Subaru engineers put them there for a purpose? I just tweeked the shields and checked the connectors. Rust wasn't an issue. If you take them off, buy a fire extinguisher.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
Yea! If you drive a lot off road and through dry leaves or park on dry grass... I took mine off in 2000 and never had a problem.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
Or if you just don't drive/park over dry grass ever. |
I am thinking of putting exhaust wrap on pipes then the heat shields.
I am getting a lot of tinning of the shield when my car cools down. only on one side I think of have a bad pre-cat. |
Thread Tools | |
Display Modes | |
