Old 06-05-2013, 09:39 PM
BackWoodsBob BackWoodsBob is offline
Re: Misfire?
Originally Posted by TomsSVX View Post
Bob, have you checked for spark or fuel yet? I wouldn't go straight to compression loss without checking the basics first.
Vic, try disconnecting the fuel injectors one by one until you find one or more cylinders that do NOT change the idle or create a worse missfire. This will help you isolate which cylinder(s) is causing the issue. Is the check engine light on?
It is not very safe the drive the car this way. Excessive fuel in the exhaust system can cause a fire if the cats get hot enough, not to mention it will and more than likely already has done damage to the cats.
If it is a single cylinder my money is on a coil since it seems like there is fuel if its getting to the exhaust. If it is multiple cylinders there could be a bad timing sensor. So try to isolate where the issue is stemming from
Smells of fuel, the spark plug was fouled when I pulled it so it's getting fuel. The injector clicks, the coil isn't grounded out and has a resistance of 1ohm.
Old 06-06-2013, 05:27 AM
Re: Misfire?
Swap the coil Bob... just moce it to another cylinder and see if the miss follows it
Vic, good to hear its running well
Old 06-06-2013, 06:20 AM
Re: Misfire?
See post # 10
Old 06-17-2013, 05:53 PM
Re: Misfire?
Done, no change, however, swapping the ignitor did produce a change!
I still have a random cut-out issue though. Not sure what's causing it, my engine will randomly lose all power while going down the road. Either putting it in neutral and revving the piss out of it, or restarting the car seems to fix it.
Old 06-17-2013, 06:08 PM
Re: Misfire?
Tap on your MAF WHILE motor is running. Mine would cut off, Mine died going around corners, backing out of parking spots, at 50 MPH. New MAF no more cutting out.
Old 06-17-2013, 06:31 PM
Re: Misfire?
Just bought it used, but I will try that next! Hope not cause I just picked it up to replace another bad maf .
Thanks for the idea!
Actually I kinda hope it is the issue, I'm tired of guessing haha.
