Old 05-15-2013, 09:47 PM
davew833 davew833 is offline
TCU stored codes vs. active codes
Will someone explain to me the difference between TCU 'stored codes' and 'active codes?' I had no flashing power light so and did the check for 'active' TCU codes and got nothing, but there was a stored code (#32) for VSS1. So since it's not an 'active' code, can I assume the VSS1 had a random malfunction, but is currently working? Or that it was repaired at some point and the code wasn't properly cleared?
davew833@yahoo.com
Former 6-time SVX owner
Old 05-16-2013, 06:58 AM
scoobydrvr scoobydrvr is offline
Re: TCU stored codes vs. active codes
Someone correct me if I'm wrong but it's my understanding that a stored code is for something that has intermittent failures or can return a range of values and has given the TCU something out of range. Either way, it has to malfunction a certain number of times before the TCU will store the code. So, it may be that VSS1 has had (for the sake of conversation) 5 failures (or out of range readings) in the past and after 3 it created the stored code.
An active code is what it sounds like: something is currently malfunctioning. I don't believe you can have active and stored codes for the same sensor, it's either one or the other, but I may be misinformed on that.
Again, someone correct me if I'm wrong. I'd love to know more about how the systems work in these cars. Hope this helps!
