Leak near Trunk area
Hello all,
I finally sealed the deal on that '92 SVX, Pearl White. The PO stated that there was a drain hole where the rear window meets the trunk area. He said that maybe the mechanic pulled off some body piece and then plugged the drain hole. (PO stated that there was water in trunk and rear floor... probably why the ABS light is on all the time). Does anyone know how I can get to this hole? What the hole is for? Is there really a drain hole there? Any experience or knowledge on this subject would be greatly appreciated. I'm an EA81 and EA82 guy. But have now graduated to the SVX. Wish me luck... please! Thanks in advance. Ron. PS: Yes... it rains in Oregon. More on that later... |
Re: Leak near Trunk area
Leaks in the trunk usually indicate rear tail light seals that leak. Yes, that will do it. Search that and there are several threads on it. Good luck.
As ensteel said the rear tail lights often let in water. This usually happens when they are removed and over torqued when replaced thus flattening and distorting the gaskets. New gaskets are available from Subaru, or you can use sealant.
If there is water on the rear floor I'd doubt that it is the tail light. Most of that water would end up in the wheel well for the spare. SO the plugged drain sounds more like it. If memory serves correct it's the drain from the sunroof of which there are 4.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
The rear sunroof drain and the power antenna drain tubes come together into one grommet, inside the side panel on the passenger side, towards the rear. They then drain to the outside. Check to see if both hoses are connected.
If you can log onto subaruparts.com, go to http://www.subaruparts.com/diag/?mod...category=863-A Or else, search "drain" and click on "antenna". Part no. 9 There are plugs that are in the bottom of the spare tire well that are not designed as drains. You can remove one but that only addresses the water there, not on your floor. We need to find the cause, not address the symptoms. Usually faulty tail light gaskets will give you lots of fogging and condensation in the lenses. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 05-18-2013 at 12:16 PM. |
