Old 04-06-2013, 10:50 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Offset Question: Highest to safely go?
Well it's spring, and that means my STi BBS wheels are going back on. These wheels fit so nicely. I was thinking the other day though, what if I put something like a 5mm spacer on each wheel to make them slightly more flush? 5mm won't hurt the bearings, and it would make the wheels have a -48 offset. What would be best to avoid rubbing? I'll put 10mm spacers on if it won't have any adverse side effects. My suspension is old and weak, and I'm no fan of rubbing. I just think it would give the car a better stance, and I"m debating doing it with the stock wheels too. Anyone attempted this yet? I may just try it out. What are the best offsets you guys have found out to work without rubbing, both front and back (I'm sure they're different)?
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 04-07-2013, 07:55 AM
Re: Offset Question: Highest to safely go?
I believe you mean +48 offset.
Old 04-07-2013, 08:57 AM
B 4 You's Avatar
#lolsvx
I did, just a typo
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-07-2013, 09:22 AM
michael's Avatar
michael michael is offline
What Potholes ???
Not sure about how safe it is but I remembered these for sale a little while ago.
http://www.subaru-svx.net/forum/show...hlight=spacers
Wanted: Steering Wheel
Old 04-07-2013, 01:16 PM
B 4 You's Avatar
#lolsvx
I don't want something that big. That will leave me around +40, which will be cutting it close. Anyone else have wheels around a 45-48 offset that doesn't rub with 225 width tires?
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
