Old 08-16-2010, 09:39 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
Re: EZ36 swap
Originally Posted by Boxersix View Post
The EZ36 is also a motor with unusual internals and is not one that can be modified cheaply if future plans soar. The motors uses offset connecting rods to achieve the correct rod ratio with the increased stroke. Good motor for what it is, but not really the best candidate for a swap. I'd stick with the 30/30R motors. Far more "adaptable" in the long run than the 36.
i was thinking about the ez30 motor also, i just don't know the exterior dimensions.
I has teh FWD LS-L
Old 08-16-2010, 09:42 PM
Nevin's Avatar
Nevin Nevin is offline
Re: EZ36 swap
Ahh!!! Just beat me to it! haha
I was gonna say the same thing. The EZ36 is a bit of an oddball really.
I would choose the EZ30 myself. Seems much more "modifiable" if you ask me. Just look at the Perrin H6 turbo build!
And for curiousity sake... How do the 30 and the 36 compare dimensionally?
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 08-16-2010, 10:36 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Re: EZ36 swap
nearly identical
Old 08-17-2010, 06:34 AM
sicksubie's Avatar
Re: EZ36 swap
I think the 36 just has a longer stroke... I could be wrong though.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 08-17-2010, 08:06 AM
Re: EZ36 swap
The EZ30 And EZ36 are both a lot smaller dimensionally (and much lighter!) than our EG33.
The EZ36 has weird bent connecting rods to allow for the longer stroke, while keeping the block the same dimensions as the EZ30 had...
Old 08-17-2010, 04:13 PM
92_LSL's Avatar
Re: EZ36 swap
dose anyone know the compression ratios of the ez36 and ez30?
I has teh FWD LS-L
Old 08-17-2010, 04:18 PM
NeedForSpeed NeedForSpeed is offline
Re: EZ36 swap
Try cars101.com
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 08-17-2010, 07:28 PM
Cam Cam is offline
Re: EZ36 swap
The EZ36 is 10.5:1 and the EZ30 is 10.7:1. Just had to it.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 08-17-2010, 09:35 PM
92_LSL's Avatar
Re: EZ36 swap
not boost friendly, also it has drive by wire.
I has teh FWD LS-L
Old 08-17-2010, 09:59 PM
Boxersix's Avatar
Re: EZ36 swap
DBW should be of little concern when swapping a motor like this. One swapping in such a motor can easily adapt a cable TB and external IAC with some simple work. Relatively easy in truth
I almost chose an EZ30 over the EG33 when I did the swap into the WRX. Availability was the final determining factor in the end but the EZ is a great motor to build on when using an aftermarket EMS. The stock EMS is not choice for a swap as the electronics around it are a bit more complicated than the EG and the harness is a nightmare to weed. Best to MS it on a budget, or go Autronic/Hydra if you're looking for a more fancy setup(nothing wrong with MS at all though!!)
The EZ36 Is a good motor for what it is in stock form. It makes great power and torque and is quite small and light for the size, even smaller than an aircooled flat 3.6 M64 from a 993. The only achilies heel it has are those damn asymetrical connecting rods in it to acheive that displacement.
I may eventually swap an EZ30 into my car if/when the EG pops. Trying to pull some weight off the nose of the car(EG33 in there + ~120lbs in skidplate and front crash beam.)
Old 08-17-2010, 10:39 PM
Re: EZ36 swap
not boost friendly
Of course not, and neither is the EG33. No n/a motor meant for n/a is going to be boost friendly other than some older iron block/iron head motors that ran around 9.5:1 compression, and even that doesn't allow for the high boost that a stock turbo or stock SC block can handle as far as boost...
Old 08-17-2010, 11:42 PM
92_LSL's Avatar
Re: EZ36 swap
all in all someone needs to build an ez30 or ez36 svx. just the thought is almost pornographic.
I has teh FWD LS-L
Old 08-17-2010, 11:49 PM
Re: EZ36 swap
I know a guy that built a EZ30 XT6... It is yellow... It's name is EZ Cheese
Old 08-17-2010, 11:53 PM
92_LSL's Avatar
Re: EZ36 swap
that sounds great to but i'm in love with the svx body styling. i wonder what 5mt would bolt up to an ez36.
I has teh FWD LS-L
Old 08-18-2010, 05:07 AM
Re: EZ36 swap
Same bell housing as all the EJ, EG, and EZ stuff, so any Legacy, Impreza, or Forester tranny will bolt up to it....
