Old 07-30-2009, 11:58 AM
Mephis Mephis is offline
Engine fans won't come on, charging system repaired.
Yep, well you know how my engine fans wouldn't come on and how it would overheat since my charging system wouldn't work in the last thread?
Well, I have a new alternator in, charging between 13-14 volts as it should be, but now the car's engine fans still refuse to come on.
Getting tired of this... Anyone have any advice? I checked all the engine compartment fuses and they're fine. I have no way to know if the relays are good. There's no check engine light.
It gets to operating temp, the gauge stops going up, even though the car overheats and the fans won't kick on.
Old 07-30-2009, 12:03 PM
BoxerFanatic's Avatar
Re: Engine fans won't come on, charging system repaired.
Could be fan relay...
but if the gauge doesn't show an over-heat, maybe the temperature sensor never trips the fans to come on, and doesn't tell the gauge to rise ...
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
SoCal LS-L's Avatar
Avalanche Alcyoneer
Theres a coolant temperature sensor just below the intake manifold on the drivers side, at the rear. Resistance test this when the car is fully hot and compare the reading with whats in the service manual.
I think the fans are actually supposed to come on automatically if the sensor is disconnected, so you might unplug it while its running and see if that kicks them on. If so, then the sensor is a likely problem.
Also the temp gauge is controlled by the temperature sender, which is seperate from the sensor. The gauge not registering an overheating condition is a common problem with resistance field gauges, they develop a magnetic "memory" of the spot they sit at most (normal operating temp), and will stay there even with a lower resistance signal. Thats why a lot of new cars peg their gauges to the max and back down when first started, to keep the resistance arc functioning properly.
Old 07-30-2009, 12:07 PM
Unplugged the temp sensor at the back on the driver's side. Fans kicked on.
I guess that means I'm ordering a temp sensor, right?
Old 07-30-2009, 12:09 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Correct, mine was like $26 from Autozone, but you might want to try a few different sources. A lot of people suggest OEM, but my $26 sensor functions just fine, I think its Beck & Arley or something.
Old 07-30-2009, 12:10 PM
Thanks for all the help. I'm calling around to try and get one today but yea autozone has that one for that price if all else fails, have to order it though. Going to check with a subaru dealership and see if I can't get anything today.
*edit*
Found it for $23 and they're going to be able to get it in today.
Old 07-30-2009, 12:11 PM
Manarius's Avatar
Manarius Manarius is offline
subarugenuineparts.com has them for like $20 something dollars. However, the Autozone one will work if you desire instant gratification.
-Jason
-Obi Wan Kenobi
Old 07-30-2009, 01:28 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Mmmmmmmmmm, instant gratification
Old 07-30-2009, 04:23 PM
Welp, replaced the part, no change. I said many colorful words and gave the garage some character, then limped the car to a subaru dealership. No more goose chases.
Old 07-30-2009, 04:39 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Thats quite odd, you confirmed the fans came on with it disconnected, so there was no power issue, just a signalling issue. Did you by chance resistance check either sensor? There have been known cases of bad "new" coolant temp sensors.... Oh well, let us know what the dealership says....
Old 07-30-2009, 06:02 PM
They refused to refund the sensor anyway.
Doesn't matter if it's good or bad, I'm still ****ting money away chasing down problems I have no way of making sure of. Dealership is probably going to have me eating ramen for a few months but what has to be done has to be done. I would sooner assure the car is in good health than I am lol. It will probably outlive me.
Old 07-30-2009, 08:09 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Well thats why I suggested testing it before replacement. A good multimeter will go a lonnnnnng ways in helping finding sensor and general electrical faults. I also hate throwing money away replacing parts trying to chase down a problem, so I usually test until my fingers bleed to confirm a part is bad. Hopefully the dealership is respectable.
Old 07-31-2009, 12:24 AM
kwren's Avatar
kwren kwren is offline
Unfortunately, respectable doesn't mean that the "mechanics" have a clue
Keith
Old 07-31-2009, 12:28 AM
I put a multi meter on it and couldn't find a setting to get any sort of reading.
Because of exactly what you said, my car is at the dealership now. I can't afford to keep wasting money even if it costs a little more.
Plus the way the car was hesitating when accelerating driving over there has me extremely concerned. I can tell all the power is there but something is trying to limit it. I guess that's limp mode since I had the temp sensor unplugged?
Old 07-31-2009, 12:31 AM
Keith
I'm willing to bet they have more of a clue than I do.
It's got more miles on a trailer this week than on the road, so apparently I can't get it fixed. Fix one thing, something else goes to hell, etcetc.
On the plus side the new alternator pulley is chromed and matches my aluminum crank shaft pully...
