Old 07-24-2009, 09:26 AM
alia176 alia176 is offline
Timing cover (front/back/side) interchangeablity?
I didn't find anything doing a cursory search on this topic. Are the timing covers from a legacy interchangeable with the SVX? I assume that a DOHC timing cover will fit all other DOHC engine regardless of 4cyl or 6cyl. Valid assumption?
Thanks.
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 07-24-2009, 09:54 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Timing cover (front/back/side) interchangeablity?
Thanks.
Nay, the SVX 3.3 is a non interference motor because the cams are permanently connected by a GEAR just behind the rear timing cover. This prevents the cams from spinning independent of one another, but as you can also see, theres only one driven cam on each bank.... and the timing cover was made to fit that configuration.
Edit: fixed...
Old 07-24-2009, 10:16 AM
ShiuludeSVX's Avatar
I was just gonna say NO.
I just spake with my local dealership, and the parts guy has always been very helpful. No, he didn't wanna chase this down for me, cause he already knew the front ends are very different. But he was gonna do it anyways.
I saved him the time, and let him know not to go with that.
But it was worth a try.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 07-25-2009, 06:41 AM
Thanks very much. I'm heading off to the junk yard today so hopefully the svx there has the timing cover intact! I know there are some legacy's there so that's why I was asking/hoping!
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 07-25-2009, 11:56 PM
svxpert svxpert is offline
<<Nay, the SVX 3.3 is a non interference motor because the cams are permanently connected by a chain just behind the rear timing cover. >>
theres a chain there? i thought it was a gear.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
Old 07-26-2009, 12:26 AM
Green1995SVX's Avatar
Correct. It's a gear.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 07-26-2009, 05:36 AM
Manarius's Avatar
Manarius Manarius is offline
If I may: http://www.canardzone.com/members/ph...ineCutaway.JPG
Cutaway picture showing the gears.
-Jason
-Obi Wan Kenobi
Old 07-26-2009, 05:49 AM
michael's Avatar
michael michael is offline
What Potholes ???
Even though one is gear driven and the other belt, who's to say the distance apart is any different. If you eliminate the gears, add a pulley and a longer belt you have the same thing. I'm not saying it will fit but, it's an idea that shouldn't be thrown out till it's proven. The SVX front cover alone is $90 new and legacys are a dime a dozen in the scrap yards.
Wanted: Steering Wheel
Old 07-26-2009, 07:46 AM
Yup, that's a good point; it may be worth to do an experiment between the two vehicles.
Luckily, the junk yard had all the bits so I pretty much scavenged the front of the donor SVX for a couple of hours yesterday.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 07-26-2009, 09:27 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Of COURSE theres a gear, chain means gear in California Have you heard our governor?
Old 07-26-2009, 03:25 PM
kwren's Avatar
kwren kwren is offline
There is an excellent reason that subaru made the gear thing exactly like they did.
Keith
Old 07-26-2009, 04:07 PM
Now lets not confuse the issue. A chain drive involves sprockets, not gears. Ask a cyclist and one in California if you are so inclined. Are yes there is a gear ratio, which gives rise to the term 24 gears, or whatever. Does the Governor guy, favour chain gangs?
Old 07-26-2009, 05:13 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Aw jeeze it was a lame attempt at saying "oops" And you know who the governor of California is right?
Hint: He was looking for Sarah Connor, coined the term "Ill be back", played a gay freezy guy in Batman and Robin, and was even pregnant once.
