Squeaky Brake Peddle
I have noticed that my brake peddle has started squeaking a bit, is there any part of it that I can oil? It's not bad, but I can notice it and I know it wasn't doing that when I purchased the car.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Re: Squeaky Brake Peddle
Sure, theres a hinge near the top, many have bushings that squeak like in a suspension. Spray white lithium grease works the best.
Peddle is what a bum does on the street corner, PEDAL is what is in your car.
There is a bar that goes through the pedals that they pivot on, not sure if you can get it out with the pedal bracket in the car or not, I've never tried taking mine out, but you can take that out and lube it up with some lithium grease and then reinstall it. Silicone spray works as well, that usually what I use at work when I work on something with a squeaky pedal.
1992 SVX LS-L #1222 Pearl White 1987 GL Turbo wagon, 5 lug conversion, D/R 5 speed (Rice killer) 1992 Dodge Ram 4x4 diesel (car hauler) 1968 Dodge Polara convertible (Camaro killer) 1990 Toyota Corolla FWD auto (330,000 mile grocery getter) 1986 VW Jetta |
Thanks I'll give that a try on my PEDAL. Probably try the spray white lithium grease suggestion.
By the way, Happy Birthday man The lithium grease will also work for your window regulator, sunroof slides, and whatever else needs a lubin'
Thread Tools | |
Display Modes | |
