Old 06-17-2009, 04:48 PM
Schralper's Avatar
Schralper Schralper is offline
fuel pump removal
ok i've got the into the top of the tank.
undid the hoses and elec. connects.
how does it come out? pic shows what I'm seeing
manual doesn't show what need to be undone for brackets to be removed (clips? bolts?),
just order in which to remove parts
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 06-17-2009, 10:34 PM
Old Fogey
Re: fuel pump removal
The piece with the horse-shoe shaped cut-out is a cover, with clip-shaped corners that have to be carefully pried loose/up to release the 3 separate pieces for removal. Driver's side metering unit must come out first before there is room for the passenger side metering unit, and finally the pump to come out. This is a pita to finagle out, and a major pita to reinstall BTW, all while sniffing hi-test fumes and thinking about sparks. This is a good time to examine and meter the potentiometer resistance of the metering units if your gauge has been misbehaving, like most, and the reason most owners just live with the behavior. Good luck to ya!
Glenn
Old 06-18-2009, 07:44 AM
Schralper's Avatar
thanx
i thought it looked like the tangs engaged clips on piece but wasn't sure.
pita is right.
WFO!
