Old 10-25-2009, 06:00 PM
kwren's Avatar
kwren kwren is offline
Re: A/C Cool on the Feet but not much from the vents
Originally Posted by Sean486 View Post
Are there multple motors? Blower Motor, Mode Door Motor, and Intake Motor. I'm a litte confused.
There are!
3 in the climate control heater unit system... Motor Actuator Mode, Motor Actuator Mix, Blower Motor. each is $99 and change.
Next step... Find out exactly what you need. In this case, a visual inspection might do wonders. Something might just have came loose.
Keith
Old 10-25-2009, 06:37 PM
Originally Posted by kwren View Post
There are!
Keith
Keith are they all behind the glove box?
Old 10-26-2009, 08:12 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I had to change the motor actuator mix, as Keith calls it, and it is located on the passenger's side by the center console. You can go through the trouble of taking out the glove box or, crawl underneath if you are thin and flexible enough. The motor is attached with two bolts and unclipping of the actuator rods. Taking out the seat helps the under dash access.
You might want to make sure you are getting power to the motors before going through the expense and trouble. Getting two motor codes is suspicious. The 13 could be just being in the garage or shade.
Gene
Gene and Ben
Old 10-26-2009, 08:31 AM
Gene
Yeah it was raining when I ran the test so I am not concerned about 13. I'll take a look in that area and see if I can get at it. Thanks Gene.
