Re: How To: Clean and Restore Headlights and Grill
Gotcha, just wanted to make sure.
They do look great though, nice job! __________________ |
Looks great!!! but your headlights were not even yellow to begin with, just hazy. I'm going to try this on my yellow ones but I don't anticipate the same results. Thanks for the info
Here's a question. I have one light that gets some moisture in it once in a while. Would placing it in the oven without pulling it apart reseal it?
1997 Boudreaux LSi 1994 SVX LSi(SOLD) Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3 |
I did this to the set on my car as well. They were extremely yellow and it removed it. Depending on how deep into the plastic the uv damage is, more or less sanding will be needed.
ALICE: 2005 Forester XT (Ice Racing Machine) River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment) |
I am not sure. You can get more of the sealing material from an auto parts store if you wanted to. BUT, our headlights are not sealed. They have two little breather tubes on the back pointing down.
For moisture inside the light - heating it in the oven with the bulbs removed might dry the inside out
As for polishing, Meguiar's has a clear plastic cleaner in addition to the clear plastic polish, I use the two of them together at work to polish headlights, and I rarely need to sand them unless they are deeply pitted or if they are excessively cloudy. I also have a 3" air polisher, it was $150 from Cornwell Tools, works great for polishing headlights. Here is the section on Meguiar's website: http://www.meguiars.com/estore/produ...ectionID=34101
1992 SVX LS-L #1222 Pearl White 1987 GL Turbo wagon, 5 lug conversion, D/R 5 speed (Rice killer) 1992 Dodge Ram 4x4 diesel (car hauler) 1968 Dodge Polara convertible (Camaro killer) 1990 Toyota Corolla FWD auto (330,000 mile grocery getter) 1986 VW Jetta |
I noticed the breather tubes but I figured I have a leak somewhere in the seal between the two halves. When I cleared the snow off the other day one light had condensation inside of it and the other didn't. The snow had been sitting on the car for a couple of days with both lights being covered.
Thats looks verry nice. Its cool to have some tip to clean stuff. Then not just bye some new one.
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
I tried it today and they came out pretty good.
Before: After
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
just like those phony weight loss systems, shapeshifter before = right after = left
found this at TSC http://www.tractorsupply.com/vehicle...storer-1031224 BlueMagic 8 oz. Headlight Lens Restorer
"Some work occaisionally is fine, but I bought the car for the road, not for the garage. " BoxerFanatic click here for fuelly mpg info |
I tried that blue magic stuff and it actually works i'll try and post the pics when i get em off my phone. Blue magic helps speed things up but i still recommend 2000 or 2500 grit and wax/polish
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
the MSDS reveals
kerosene aluminum oxide Oxirane, methyl-, polymer Ammonium hydroxide Smectite clay IIRC, the bottle does mention sanding
#28
so after you do this procidure.....is there a way to stop it from happening?
i hurd of 3M plastic "screen" protector works? i did a similar method but my headlights turnd yellow again bout 6mnths later
VICSVX 94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx |
#29
Consensus is to apply clearcoat which has u/v protectant.
#30
oh ok then, sounds easy enough
