Old 03-22-2007, 12:57 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Getting a Production class. Specs needed
The 6 page submital tech specs required that I haven't found yet. Need back up evidence (i.e. shop manuals or whatever to prove).
Wet Curb weight:
Rear window slope angle
Windshield slope angle
Rev limit miethod
Block deck height (min)
Deck clearance (min
Total Combustion chamber volume
Valve head dia (max
Valve material
Connceting rod length (center to center)
Connecting rod material:
Connceting rod mass:
Piston, pin rod and ring(s) mass (min):
Crankshaft mass
Lift @ lob (max)
Lift @ valve (max)
Rocker arm ratio
Tappet Type
Throttle body bore diameter:
Spring material dia/thikness
Overall spring dia/Width
Any help would be greatly appriciated.
Old 03-22-2007, 01:37 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Wet Curb weight:
Rev limit miethod electronic - spark cut out (?)
Deck clearance (min I believe it's actually negative, as the piston extends above the deck at TDC
Valve head dia (max Intake=36mm, Exhaust=32mm
Valve material
Connceting rod mass: 620 g
Crankshaft mass
Lift @ lob (max) 7mm intake, 8mm exhaust
Lift @ valve (max) 7mm intake, 8mm exhaust
Rocker arm ratio n/a
Tappet Type hydraulic
Throttle body bore diameter: 63mm each
Ben,
Hope this helps. I've got some of the other figures, just not at work
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
