Old 04-03-2002, 09:12 AM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
Fuel filter replacement
I've seen several suggestions lately about replacing the fuel filter every so often. I've had the car 20,000 miles without doing this and I'm not sure the record before that so I figured I might as well.
Any tips on how to do it, where it is located, what it looks like, etc? I've never worked on cars much before until this board, but since I have changed spark plugs, done the alternator upgrade, and cleaned intake and throttle body. So this is the next step.
Also, for the new filter any recommendations? Is it just something you can get off the shelf?
Thanks in advance.
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 04-03-2002, 09:28 AM
SuperRuu
Filter
Filter I'm not sure exactilly but i think there might be 2
even 3. i owned a 83 wagon and it had 3
on the svx the one under the hood is right on the
drivers side strut tower it looks like a mini coffee can
with nipples. as for the other ones ? i'm gonna call subie.
Old 04-03-2002, 02:36 PM
wawazat??'s Avatar
Yeah, I'm still around
Hey Troy
Fuel filter is in the engine compartment. It is a canister with multiple small rubber hoses coming oot of the top. It is located on the drivers side, between the front strut housing (the future home of your new Koni's!) and the radiator overflow bottle. One screw clamp holds the filter in place. Easy to get to easy to replace. Do yourself a favor though and either bleed off the fuel pressure or let the system bleed down over night to avoid a finely atomized flammable fuel spray cologne application .
If you were Beav, you'd probably tempt fate by having a lit stogie in your trap when you removed the hoses, but then again we all know that he's a manly man's man
Todd
Down to none
Old 04-03-2002, 03:22 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Re: Hey Troy
Originally posted by wawazat??
If you were Beav, you'd probably tempt fate by having a lit stogie on your trap when you removed the hoses, but then again we all no that he's a manly man's man
Todd
You've been peeking again, haven't you? Not any more, I finally gave up the stogies when the doc re-routed my plumbing last Sept.
Beav
Old 04-03-2002, 04:02 PM
wawazat??'s Avatar
Re: Hey Troy
Todd
Wrong button, sorry my bad!
Down to none
Old 04-03-2002, 05:04 PM
svx_commuter's Avatar
I find the hoses a pain to get off so I use channel locks as a lever to pry off the hoses. This works real well.
Old 04-03-2002, 09:08 PM
sk8ing19
I did the fuel filter about a week ago and word to the wise, clamp the damn hose. I didn't and found out just how bad gas taste. Good luck.
Later,
