Old 02-25-2002, 03:30 PM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
Question Cleaning the throttle body
OK, I'm not a mechanic and have never done mechanical type work on my cars (other than oil changes) until the SVX. I've just heard too many stories of shops mistreating our cars, aside from the fact that it is often a LOT of money for simple fixes and procedures. Thanks to this site, I've used a lot of those fixes and have learned a lot about taking care of my car.
So with that said, don't laugh to hard. I did a search and found several posts about "cleaning the throttle body" among the "Tune-Up" things to do. (I'll probably be asking about some of the others, but one thing at a time) So first, what and where is the throttle body? And then, what is the procedure?
Thanks guys!
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 02-25-2002, 04:03 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Cleaning the throttle body
Thanks guys!
Troy,
Your throttle body is located under your H6 Cover (be careful not to lose the little screw-like clips that hold it on). Take it off and you'll see two large rubber hoses held on by large worm-gear clamps. Start by loosening those clamps. Once done, unsnap your air box (where your filter is). You'll also need to find a few hoses that are attached to the plastic bits connected to the intake (large plastic ductwork), as wall as unplug the electrical connector to your MAF (the thing that looks like a small Pizza Hut, in the plastic "ductwork" configuration). Once all that stuff is removed, the orifices from which you undid the large clamps is your throttle body. spray those orifices liberally with carb/choke or throttle body cleaner. That will clean out accumulated varnish and other gunk. Then, open the butterflies by depressing the accelerator (you'll see the link to the butterflies on the passenger's side -- if I remember correctly -- attached to the accelerator cable -- just depress that). Once the butterflies are open, continue to liberally spray cleaner into those areas until the cleaner begins to run clear. Occasionally use a mirror to check and make sure the areas are clean. Once you've gotten it all cleaned up, and used a rag to dry up any remaining cleaner in the intake, then, reconnect the intake ductwork and you're done.
As I told one member, you may experience some rough running on start up and puffs of white smoke -- that's normal. It's your car burning off the cleaner that's still in the intake. Just drive it around a little while and it'll smooth out -- plus, your ECU will begin to adjust for the freer flow of air.
Good luck.
Randy Johnson
Mike Davis -- at Reading VI
Old 02-25-2002, 04:09 PM
Was MacGyver
Thanks Randy!
Thanks! I had seen you suggested this to other's in my search, but had not seen the specifics. As always, very well written instructions, I shall give it a try!
Troy
Old 02-25-2002, 04:13 PM
How often should this be done? If the car seems to be running ok, should I do it just out of normal maintenance? Thanks
Old 02-25-2002, 09:27 PM
Aredubjay's Avatar
The mechanic who has done most of the work on my cars (unfortunately, not on the SVX, though), suggests you clean the throttle body at every other oil change, just to be safe.
Randy Johnson
Old 04-20-2002, 09:06 PM
gcookaustin
Re: Re: Cleaning the throttle body
Originally posted by Aredubjay
Troy,
Why remove all that stuff? Can just the two big hoses be undone from the throttle body?
I don't have any clips for my H-6 cover? When I got the car there was only one, now the other has disappeared so it's just sitting on top. Can I get some more or do I just use a nut and bolt now?
Old 04-21-2002, 04:52 AM
Never2phat Never2phat is offline
I think I paid about $5 for the two clips at my Subie dealer
B.C.
Old 04-22-2002, 12:33 PM
Aredubjay's Avatar
As Brian said, the clips are cheap. They're available at subaruparts.com. Just to to the engine diagram.
The H-6 cover has to come off to get to the hoses. You COULD just undo the hoses, but there are smaller hoses restricting the movement of the "two big hoses." It's much easier to get the can of cleaner behind the butterflies if you remove the stuff. You'll see what I mean, once you try.
Randy Johnson
Old 04-22-2002, 02:24 PM
gcookaustin
Ah okay, I see that makes sense then.
I'll order the clips along with a driver's power window switch. I took it out to clean it / look at the breaking driver's switch and I couldn't get it back together without disabling the P/W lock. Also I broke the switch even more. So now there's about four individual things wrong with my switches so that's a good excuse to get a new box
Old 04-22-2002, 03:34 PM
Aredubjay's Avatar
Glad I could help . . . I think.
Randy Johnson
