Old 06-25-2005, 04:50 PM
simpreza2
Oil on top of engine block?
I went to look at 92 SVX today and when checking it out it had something, looked like oil, on top of the block under the intake manifold. I couldnt get a sample of it as we just got back from a drive and the engine was very hot. Where would this be comming from? I know the valve cover gaskets were going but they were leaking from the bottom of the engine, even if it was from the top I dont uinderstand how it got all over the top of the block.
Thanks
Jon
Old 06-25-2005, 06:18 PM
thundering02's Avatar
Giong back to the beaters...
PCV valve is up there and it has oil running (well venting) through right up in that area.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 06-25-2005, 06:31 PM
Subafreak's Avatar
Superbeast
The IRIS valve ussually leaks a little oil right in the center of the block. It shouldn't be anything to really worry about, it shouldn't be leaking that much it just builds up over time. I ussualy steam clean my engine once a year so it dosn't build up much over that time period.
Old 06-26-2005, 08:46 AM
immortal_suby's Avatar
Thread Killah
Yep - IRIS valve is probably the culprit. Give it a good cleaning with some simple green and then see how much builds up. Root cause of the problem though could be excessive oil in the intake. I'd remove the intake boot and clean out the inside and also replace the PCV valve.
Does your oil dipstick pop up?
Locker Link
2015 BRZ Limited 6MT
Old 06-28-2005, 08:33 AM
simpreza2
Note sure. I just went to look at it to see if it was worth buying. It didint pop up durring the test drive.
Old 06-28-2005, 08:50 AM
dcarrb dcarrb is offline
It seems a common occurrence, my car included. As long as it's minimal, you shouldn't let it put off an SVX that otherwise appears to be a good buy.
dcb
Old 06-28-2005, 09:50 AM
I dissagree...
I think you have a bad O-ring in your PS pump resorvoir....50 cent and 15 minutes you'll be all fixed up...
Old 06-28-2005, 08:11 PM
Subafreak's Avatar
Superbeast
Originally Posted by huck369
I dissagree...
Well yeah, there is that. That will usually leave a much bigger puddle much faster, but like you say still not a big deal to fix.
Old 06-28-2005, 08:29 PM
And it's red rather than black...
Old 06-28-2005, 08:32 PM
Subafreak's Avatar
Superbeast
Well that depends.
