Old 06-10-2005, 05:57 PM
svxthc's Avatar
svxthc svxthc is offline
Rear Grinding Noise on Takeoff
It seems after I start the car and accelerate there is this click/grinding sound coming from the rear lower end, almost sounding like the exhaust is making the noise. I let the car warm up for roughly a minute and I still get this abbreviated sound coming from the back of the car for the first quarter mile of the ride whenever I move from a stop. Any ideas what this could be? It's nothing major and it only happens it seems before the car has warmed up. I was just wondering if any of you had experienced anything similar in your svx!
1993 SVX Anniversary Edition #64
Old 06-10-2005, 07:04 PM
Could be the differential.
Old 06-11-2005, 04:20 PM
Are you sure it's not the exhaust?
Old 06-11-2005, 04:40 PM
One way to find out is to rev the engine a little in park while it's cold. If it is the exhaust it won't matter whether it's moving or not. If it's a drivetrain component chances are it won't make the noise parked.
Old 06-11-2005, 06:49 PM
svxthc's Avatar
Like a dummy I revved it in park like 5 seconds after starting it up before it had the chance to heat up and it started smoking out of the exhaust, not doing that again.
Old 06-11-2005, 07:02 PM
How high did you go? Simulating actual driving would only require you going up to about 2-2.5k.
If you drive when it's cold like that it does the same thing...
Did you listen for the noise?
Old 06-13-2005, 09:34 AM
Another way to test is to load up the drivetrain. Hold the brake, put it in D and bring the RPM up to 2k temporarily and listen for the noise. Don't hold it there for long as that creates tremendous heat in the tranny.
Old 06-13-2005, 12:41 PM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
If it is only on acceleration,
I would put my money on a U-joint some where in the prop shaft (driveshaft)
I just replaced mine. There is a big heat shield covering the front two joints, so you may not be able to see it.
You can sort of check it by putting the 10amp fuse in (under the hood center, driver side) in the 2wd spot. This will disengage the rear wheel drive.
http://www.subaruparts.com/diag/?mod...category=199-1
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
