Old 05-30-2005, 10:12 AM
videozoo
runs well then dies
have 92 svx starts fine, runs great but a few times a day while drive could be on highway going 60 or 20 in streets or at ide she just drops dead like if some one cut gas flow.... ive change pump and filters still happens any one have any suggestions HELP
Old 05-30-2005, 10:59 AM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
any codes? does it start right back up again?
Old 05-31-2005, 09:19 AM
red95svx
I suspect a bad crank or cam sensor. The sudden engine stoppage is a classic symptom.
Old 06-13-2005, 04:48 AM
BLACK ON CHROME
This may be my prob
My SVX is doing the same thing,
the first few times that it stalled was at high speeds but as time passed it turned to more of a low speed issue.
I have had it at my dealership 3 times and they cannot diagnose it.
PLEASE HELP
Old 06-13-2005, 09:11 AM
red95svx
Again, I think it is a bad crank and/or cam sensor. Sudden engine stoppage is a classic symptom of these sensors gone bad. You should get a check engine light though.
Old 06-13-2005, 09:26 PM
BLACK ON CHROME
With the cam sensor failure would that result in stalling upto four times in quick succession?
Is there any way to test for this?
I have not had any check engine light,
The only suggestion was my air flow monitor but then that was dismissed.
I dont have much patience left
Old 06-14-2005, 05:39 AM
red95svx
You need to test each sensor with a multimeter. A bad crank or cam sensor can make it difficult to start the car and can make the engine stop running at any time.
Old 07-05-2005, 06:11 AM
SimboSVX
Blacky, have you had any further joy with solving your problem? My 92 Jap import suffered this exact issue and I traced it to a failing Mass Airflow Sensor. I had my dealer replace it and mine is the happiest SVX I've had in 2 years. Seems slow degradation then periodic failure is quite normal.
Anyway, hope you get it sorted, I fully feel for you, it's like russian roulette, just waiting for the blinkin' thing to cough and die.
