Old 05-25-2005, 02:55 PM
92AWDSVX
Originally Posted by Beav
If the headlamps dim significantly while trying to start (but not turning over) and jumping the battery didn't help it's either a bad cable or starter. If the lights don't dim much try jumping the battery cable terminal of the starter to the small terminal on the solenoid. If it still doesn't start you probably need a new starter/solenoid. Jumping the two large terminals on the starter isn't a very safe procedure but as a last resort, after trying the above procedures, you probably have a bad starter.
i may have forgot to mention but i replaced the starter already
Old 05-25-2005, 03:02 PM
fl_svx
I posted my suggestion in the other thread, I think it may well be a grounding issue. Ensure you engine is properly grounded to the chassis, an old battery cable connected between the block and chassis will tell if this is the problem.
John
Old 05-25-2005, 03:06 PM
KCROGUEDOG
i had a problem on a blazer i had that clicked and wouldnt start so i replaced the battery stater and alternator. still no luck it was a fuel pump. waste of cash and lots of hassle and to top it of the pump was in the tank. i have not heard anything on svxes fuel pumps ever gone bad.
Old 05-25-2005, 03:07 PM
92AWDSVX
John
ok man i will check all that **** out, seems to be a big pain in the ass, this damn car is soo weird it has a mind of its own hahah
Old 05-25-2005, 04:27 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
John
This is a common XT6 problem as they age. The cable looks good on the outside but is corroded about a 1/2 inch in. Replacing the cables works. My XT would click and click on end until it would start finally so that could be it too.
Old 05-25-2005, 05:23 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
my svx would do the same thing for a day or two awhile back. it turned out to be a bad neg. battery cable. while it looked to be in ok condition and the terminals showed no corrosion, the cable was bad about half way in the middle of it. found this out while shaking everything i could touch while someone else continuousely tried to crank it.
Old 05-25-2005, 05:25 PM
Can the mods please merge these 2 threads?
Old 05-25-2005, 05:49 PM
immortal_suby's Avatar
Thread Killah
already did an hour ago
Locker Link
2015 BRZ Limited 6MT
Old 05-25-2005, 05:57 PM
Oops...didn't realise that until now. Thanks for being on the ball!
Old 05-25-2005, 09:52 PM
92AWDSVX
Ok guys well im gonna try that stuff starting with the cheapest things 1st.. and work my way up.. i need to get it running though, thanks for the help.. anybody esle have any suggestions??
