View Poll Results: Have you ruined a set of performance tires?
Yes 12 60.00%
No 8 40.00%
Voters: 20. You may not vote on this poll
Old 09-10-2004, 01:11 PM
svx_commuter's Avatar
Did you ruin a set of performance tires?
I ran a set of Yoko AVS db's at the door plate rating and they ended up cupped and noise as h@ll. I found out after the fact that I should have used a higher pressure above the Subaru recommended tire pressure, 40/36 psi.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 09-10-2004, 01:27 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Interesting poll/thread. I haven't ruined a set of tires, but I'm alsmost wondering if I should inflate my Bridgestones to the pressures you mentioned (40/36). I currently have them set at the factory recommendation like you did...
-Chike
2006 Steel Gray WRX TR (sold)
Old 09-10-2004, 01:42 PM
dcarrb dcarrb is offline
Those are the exact pressures I use. My Bridgestone Potenzas came on the car and after 14,000 miles seem to be wearing reasonably well; but something about my driving (the curvy roads around here, I imagine) really scrubs-down the shoulders, and I'm trying to get 'em to ride up more on the center of the tread.
dcb
Old 09-10-2004, 02:28 PM
I kinda ruined my Yoko AVS db S2's by autocrossing them a couple times. The tread on the outsides of the center block feathered. I don't recommend autocrossing with any tires with large rain grooves (unless it's raining ).
Old 09-10-2004, 04:38 PM
immortal_suby's Avatar
Thread Killah
I run 45/42 on my 17" tires and around 42/38 on stock size tires on the wife's svx. The tires wear alot better.
I ran my falken azenis down to the threads at that higher pressure with no cupping.
I ruined 2 sets of tires - avs db's and avid v4's by running them at the subaru recommended pressure. Never again. Car handles better at the higher pressure also.
Locker Link
2015 BRZ Limited 6MT
CGLathrop
I wouldnt say ruined..but
I too also found that my tires where wearing down on the edges more then in the middle. So I bumped up my pressure to 37 front, 33 rear. It might not be enough still, but I am not going to buy another set of tires till the middle is worn down too.
Old 09-10-2004, 05:26 PM
mikecg's Avatar
mikecg mikecg is offline
I never pay attention to the what the door says. I go by the what the printing on the tire says.
Old 09-10-2004, 06:36 PM
seasvx's Avatar
seasvx seasvx is offline
33/29
37/33
40/36
45/42:
...what's the reason (or the physics) behind running the rears @ 10% lower pressure than fronts? and does this logic apply equally for fwd vs. awd variants? (ok, you engineers; here's your chance)
Old 09-10-2004, 06:43 PM
LarryIII LarryIII is offline
I did not ruin the tires but I wore out a set of TOYO Proxes T-1S tires. Using that set of tiresto their fullest , I also managed to wear out a set of rear wheel bearings, but it was one heck of a ride while it lasted.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 09-10-2004, 07:39 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Ruined a set of Toyo Proxes FZ4s. Not sure if it was using door plate tire pressures, or if it was bad struts, but the shoulders wore unevenly (some areas flat, some almost full tread), and they got pretty noisy. I could've run them for a while longer, but the noise was bugging me.
Old 09-10-2004, 07:40 PM
Thread Killah
Re: ???
Originally posted by seasvx
33/29
37/33
40/36
45/42:
I'm not going to attempt to explain - I'm sure someone else could do a better job.
I got to my tire pressures by trial and error. I started with equally high pressure and then backed down on the rear end until the car felt more stable. It feels a little squirrely with the rears at the same pressure as the fronts. I found it feels best with the rears about 4psi lower no matter what the total height of pressure is.
Locker Link
Old 09-10-2004, 07:43 PM
I run with slightly lower pressure, and I'm sure I should run about 10 psi higher.
I noticed a lot of wear on the inside and I definitely won't run these in the snow.
They are destroyed.
Old 09-10-2004, 07:55 PM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
Re: ???
I haven't ruined them yet, and they haven't ruined me. (Whichever comes first.) The "feathering' problem dcarrb and Earthworm mentioned is not new to me. These tires are first I've ever owned which address this problem. "Look Ma, no tread!" ...on the outside anyway. Seriously - it's so shallow that I believe it's actually meant to wear away. The inside tread, where there actually are quite a few more grooves, is much, much deeper. In addition to rain-handling, I think this is also to promote even wear with exaggerated camber settings.
I've been watching these things like a hawk. So far, they've been wearing very evenly, but it's a little too early to tell for sure. Don't worry, I'll have the results soon because these things rock! They stick so well they're kinda unpleasant to drive. Cornering is painful, and so is braking. One touch of the wheel and it's like glancing off a jersey barrier. I'm sure it'll be a totally different story when it snows. Their wet traction is rated as "poor" by The Tire Rack, but Michelin just says "N/A." I entirely disagree with The Tire Rack. In the rain they are worlds better than anything I've ever driven before. They will hydroplane a bit more easily, but only if it's a considerably deep puddle. If it's just damp, they're amazing. (245/45-16)
Because there is less weight on the rear tires. They don't squish as much and need less pressure to hold things up. That's why you should put more air in your tires if you've got a heavy load.
UberLocker
Old 09-10-2004, 08:19 PM
Sidewinder's Avatar
Sidewinder Sidewinder is offline
Send a message via AIM to Sidewinder Send a message via MSN to Sidewinder
I had a set of Eagle HPs on the car. I took them in because there was some vibration. I thought the alignment or balance was off. Turns out, three of the four tires were SPLITTING on the inner walls and coming apart. Not cool. I don't think I did that, but perhaps it was something wrong with the car.
So, I got four Assurance tires (for cheap) and got an alignment. Everything should be better now, and those tires rock!
Eric
1994 Bordeaux Pearl SVX LSi
"The SVX — Where, they wondered, do you put the kayak?"
Old 09-11-2004, 01:12 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
So what pressure would you guys recommend for 225/40/18's?
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
