Old 11-15-2001, 12:21 PM
Lowered SVX
i need a little help resolving a tall tale.
i got a friend who wants to modify a justy (yes i know) and he was telling about some diesel speed truck that runs in the salt flats. anyway he said the truck had five turbos and two superchargers.
first of all is there a limit to the number of turbos you can put on a car? i have only ever seen or heard of two at a time. (maybe three)
secondly is it possible to run a car with different types of induction systems? (turbo and supercharger)
lastly what would be the advantage to doing something like that?
(maybe this should be in the technical forum.....randy feel free to move it if you think it should be there.)
"Too much fun to drive!"
Old 11-15-2001, 12:50 PM
cocacola08's Avatar
cocacola08 cocacola08 is offline
Send a message via ICQ to cocacola08 Send a message via AIM to cocacola08 Send a message via Yahoo to cocacola08
I've head of quad-turbo, but never combining super & turbo
Kev
kevin.m.sheets@verizon.net
Old 11-15-2001, 01:03 PM
Mr. Pockets's Avatar
Moderator
Re: i need a little help resolving a tall tale.
I know where your friend saw it. Last week on Speedvision there was an episode of Classic Road Show filmed on the Bonneville Salt Flats. I watched it, and got into work later than usual, because there were LSR classes I'd never seen before.
One of those classes was Diesel. Two trucks were featured. One of them was a 40s semi tractor in which the owner had dropped a 12 or 16-cyl Diesel engine he got out of a tugboat. The two superchargers, and the four turbochargers feeding them, produced 62 pounds of boost.
I believe their top speed was somewhere around 230mph. The noise and the column of sooty Diesel smoke was impressive, to be sure.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 11-15-2001, 01:10 PM
Moderator
I found it...
It was a pain in the ass, but I found the home site for 'The Phoenix,' which is the truck in question.
http://www.phoenixdiesel.com/
Heh...an estimated HP rating of 3750+...
2005 Outback
END OF LINE
Old 11-15-2001, 02:10 PM
alex_umn alex_umn is offline
I live in a drawer!
Send a message via AIM to alex_umn
As a side note, there have been some cars out there with both super- and turbochargers. I think the arguement is that with a hi-boost turbo, power will be low until the exhaust is able to turn the turbine, so power is low until maybe 3500 rpm or somesuch. The supercharger is mechanicaly driven off the engine crank, so it will operate throughout the rpm range (theoretically), and thus take care of the low-end power issues.
I think some custom-modified Ferraris have had both systems...and for some reason some Mazda in the European market sticks out in my minds as well.
Anyone interested in a diesel SVX?
Just kidding.
Old 11-15-2001, 02:22 PM
Lowered SVX
well.....now i feel horrible...
i beat this guy up on the fact that there is no way anyone would be stupid enough to put both a turbo and supercharger on any car. i kind of believed him about the semi.....only because there is no way anyone could make that up.
this is one of those keep your mouth shut if you are absolutely sure moments.
Old 11-15-2001, 04:22 PM
GM Diesel blowers
If the motor was a GM diesel. They use a positive displacement blower to start and run, being a two stroke with no crankcase compression. The turbo for running boost The bigger V engines have a pair of each.
I don't think it would fit under the SVX hood, though 'Huck" might squeeze it in, with the 10 speed behind.
Old 11-15-2001, 04:59 PM
SVXphile's Avatar
SVXphile SVXphile is offline
Ain't it the truth?
Send a message via Yahoo to SVXphile
Phoenix...the truck
Did anyone else catch this in the description of the truck?
<Rear Wheels: Boeing 727 Main Gear>
I guess they can handle the weight! Don
Cats: Clio, Inky, Sheba, Sparky, Rocky, Cali, Scooter
3 cars: 02 SVT Focus, 2012 Versa...2015 Fiat 500
currently SVX-less
1 wife ("She, who must be obeyed..")
"One advantage of being disorderly is that one is constantly making exciting discoveries"
Old 11-15-2001, 05:02 PM
Moderator
Re: Phoenix...the truck
I did, and I was wondering about the weight figure right after: 18,000 pounds. The way it's written, it looks like they're saying the wheels weigh 18,000 pounds...but I figure they mean the whole truck...
2005 Outback
END OF LINE
Old 11-15-2001, 05:12 PM
SVXphile's Avatar
Ain't it the truth?
Oh chute!!!!
...and I wonder how many parachutes it takes to slow all that down from 200+mph?
Whoaaaaaaaaaaaaaaaaaaaa Nelly!!!!!!!!
"Antelope Freeway...1 mile"......."Antelope Freeway...1/2 mile"......"Antelope Freeway.......
currently SVX-less
Old 11-15-2001, 05:14 PM
Moderator
Re: Oh chute!!!!
We may have finally found a vehicle that is more effective at warping its rotors.
I shouldn't talk - I'm about to replace mine and they're original with 127k miles on them.
2005 Outback
END OF LINE
Old 11-15-2001, 05:34 PM
SVXphile's Avatar
Ain't it the truth?
rotors
Speaking of rotors, have you ever seen those pictures from the underside of the Nascar cars? Wheel cams or rotor cams or something like that. Especially at road courses or Martinsville? Boy those suckers get cherry red! Sometimes they even melt the bead on the tires an blow them out. Heaps of heat!
Don
currently SVX-less
Old 11-15-2001, 05:57 PM
Re: GM Diesel blowers
HEY! My next project!
Well........Maybe not, but I would like to fab up a Supercharger for my SVX (never did like turbos {no offense to anyone with one}), but don't see having the cash flow for a major project like that in my near future
I'll just have to be happy with my 5-Speed for awhile
Old 11-15-2001, 07:17 PM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
Both Super & Turbo
Many of the trucks I drove in the military had both superchargers AND tubos on them. The SuperHET (heavy equipment transport-to haul tanks) has a Detriot diesel, two stroke, V-8 with twin turbos feeding a large roots supercharger. Most of these monster engines are refered to as the Detroit Super Silver "E" series if I recall right. Also if memory serves me right the PLS (patetized loading system) and the HEMTT all use similar versions of this motor.
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 11-15-2001, 10:28 PM
249SVX 249SVX is offline
still in love with Hannah
Re: Both Super & Turbo
About the different induction thingy. There was a MK1 MR2 (modified) that used the supercharger to spool up the big a***d turbo that was on it. Made somewhere around 400hp. Not bad for a 1.6 liter.
silver 92 SVX-"Hannah" -R.I.P. NOV. 1991-jAN. 17, 2003
red white and blue 2000 Suzuki TL1000-r-"Bethany" This grips me more than a muddy old river or reclining Buddha.(now running Metzlers!
black 1987 Toyota MR2-"Helga" -Turbo conversion will now commence.
1996 Legacy Outback-"Gilda" white with brown trim
