Old 11-01-2003, 05:34 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
Quick help, radar install, which wire on cig lighter?
Hey guys, i'm hard-wiring my radar, so there's no plugs.
Which wire coming off the cig. lighter do i use for the power?
There's a black (which i assume is ground), a solid red, and a red w/ green stripe.
I've tried both the reds in numerous spots (before/after the white clip), and none have worked.
I dont have a voltmeter (sorry ), so i cant measure which wire carries the 12v power.
Any quick help please??
Edit: OR is there another wire that I could tap in to? Needs to be switched and 12v.
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 11-01-2003, 05:55 PM
Bwana's Avatar
*Special* Member
Nevermind guys, i ran it off the stereo power.
I love you Mike.
Old 11-01-2003, 06:08 PM
Green1995SVX
I love you too!
Old 11-01-2003, 10:59 PM
Bwana's Avatar
*Special* Member
Old 11-03-2003, 03:30 AM
The Molinator
Exclamation VALENTINE ONE!
I know they're expensive. But, just in case you'd rather buy a primo (OK, yes, it's expensive) detector, instead of paying for speeding tickets, you have to get a Valentine One!
Like the ad says (from Car and Driver review of unit): "Once you live with the arrows, you'll wonder how you ever managed without them!"
It saved me 3 times this week, city AND country!
P.S. $400. You can program out "useless" bands, like I take out X in my area (not police, just shopping centers, etc.). Arrows show position of radar (front, side or rear!)
P.P.S. I do miss the sexy ladies voice on my cobra detector, tho! "Be careful! . . . Ka band radar!"
Jim
Old 11-03-2003, 09:23 AM
The green wire with the red stripe is the 12V switched power lead. You can access it from behind the snap off panel on the driver's side of the console (The same panel you use to get to the antenna wires)
Old 11-04-2003, 12:04 PM
Bwana's Avatar
*Special* Member
What's that you say? V1??
Bwana's Avatar
*Special* Member
Old 11-04-2003, 01:35 PM
The Molinator
Exclamation YES SIR! DAT'S IT!
Mine is windshield mounted and hard-wired. I have never installed the remote display which I intend to mount on dash by trouble lites >> someday, if I can get the BEAST running OK!
Don't you just love the arrows?!
Jim
Old 11-04-2003, 07:04 PM
JLittell
How does your radar do through our space aged metallic windows?
Old 11-04-2003, 09:25 PM
Bwana's Avatar
*Special* Member
Because it's the best :P...serioiusly though, my friend has a Passport 8500 in his monte carlo (with normal glass...), and our two detectors were just about even in the distance from the radar when they picked it up.
So, either i dont have special glass (which i KNOW i do...), or the glass doesnt effect it that much (which i know it does...), or the V1 is superior!
My garage door opener works only when im <2ft away from the door, lol. and that's on a brand new battery.
Old 11-10-2003, 04:05 AM
The Molinator
Lightbulb Titanium "radiation space shield" windshield
I don't know how much our windshield blocks. But when I found out about this issue on this website, I thought it explained why my V One was not apparently picking up Ka band radar at the purported 1 1/2 mile distance. However, it is better than my Cobra (miss the sexy female voice!), but didn't test against the Passport 8500 when I had (tested, returned) it. [If you're serious about getting one or the other, I suggest purchasing both. You can mount both temporarily with cigarette plug (may need splitter>>cheap), then use for almost 30 days, before returning (full refund most retail) the one you don't like as well!]
They're right, I LOVE THE ARROWS!!!
P.S. I should say this V1 has "saved me" at least 10 times in the last 2 to 3 months!
Jim
