Old 07-22-2003, 11:52 AM
Brake bleeding
Has anyone out there used the Speedi-bleed power brake fluid bleeding system? http://www.vq-speedi.com/
It looks to be a fairly effective way to bleed the brake/abs system using only one person. I know some shops use this or a variation of it.
Old 07-22-2003, 11:57 AM
mbtoloczko's Avatar
sans SVX
I haven't tried that system, but I have a set of Russell Speed Bleeders on my SVX. These things have a spring loaded stop ball in the bleeder screw, so you don't need someone down at the bleeder valve to close it every time you pump the pedal. They replace the original bleeder screws. They work great. You can get them at Summit Racing.
Mychailo
Visit my locker
Old 07-22-2003, 12:02 PM
I saw a similar item here for $7.00 each plus a shipping charge of only $3.00 /set. Looks like another way to go and much cheaper.
http://www.speedbleeder.com/
Old 07-22-2003, 12:40 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Perhaps you can convince John McKenna to build you one of his famous "Frankenbleeders."
Randy Johnson
Mike Davis -- at Reading VI
Old 07-22-2003, 02:38 PM
mbtoloczko's Avatar
sans SVX
Yeah, they look the same and price is better.
Mychailo
Visit my locker
Old 07-22-2003, 02:53 PM
They are also available in 303 stainless steel for $15.00 each
Old 07-22-2003, 04:09 PM
why do you want to bleed them?
Old 07-22-2003, 05:12 PM
To get the air out of the system.
Do you know what size the SVX uses? I was going to order a set, and I thought if you knew, I wouldn't have to go out and try to decide myself. Thanks
Old 07-22-2003, 06:57 PM
svx_commuter's Avatar
The brake fluid should be flushed once a year.
Was that RJ I saw up there.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 07-23-2003, 12:42 PM
According to the speedibleeder site, the SVX takes their part # SB1010. http://www.speedbleeder.com/automobi...s.htm#Sterling
It is a 10mm x 1.0 thread and measures 1.37" (34.95mm) in overall length
Old 07-23-2003, 03:53 PM
Thank You John. That is very helpful.
Old 07-23-2003, 04:58 PM
Aredubjay's Avatar
No. You're seeing things. Go back to work.
Randy Johnson
