How many MPG have people gained from going manual?
I know the trannies are more efficient but how much more? I am currently getting about 23 MPG on average with about 75% highway driving. On straight highway I am getting about 30 MPG. I'm wonder how much higher it could go, assuming the car was in as good running condition as mine is.
Re: How many MPG have people gained from going manual?
I lost a few highway MPG for sure, due to the very low gearing. The answer to this question is entirely dependent upon the gearing of the trans. With the EG33, because of how wonderfully much low-end torque it makes, you can get away with really high 5th gearing (I assume you're uninterested in 6-spd $$), and you should get very good highway mpg, with nice, low, quiet cruising RPM. For city MPG, it depends a lot on the driving habits/style of the driver. Using my 6-speed SVX, my brother and I have gotten very different city MPG.
My highway mileage dropped a fair chunk after installing my 6-speed. However, I blew a fuel line shortly after that, so I may have been leaking into nowhere and just appeared to have garbage mileage. The jury is out. With the 4EAT I was consistently in the 27-30 MPG range on the highway and ~21 in town when not driving like a tool.
I get 20-21 unless I'm on the highway, then I get almost 28. That could also be due to my exhaust, it's a 2" to a 3" catback.
Gonna switch it to a 2.25" secondary to 3" header-back. With a little luck I'll gain top end and some mpgs |
I am happy with mine. I was more concerned with the SPG ( SMILES PER GALLON)
My in town was in the mid 12. Small town tons of lights. Lucky if I get out of 3rd. I get 15 now. Highway is about 27 again not flat terrain. Oh and I love the sound of the exhaust
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. Last edited by Conn SVX; 08-12-2013 at 04:45 PM. |
Yea, it's not the final drive, it's the 6th gear, .842.
02-05 WRX 5 speed: .738 Final drive: 3.9 06-07 WRX 5 speed: .738 Final drive: 3.7 08+ WRX 5 speed: .780 Final drive 3.9 04+ STI 6 speed: .756 Final drive: 3.9 07 Legacy Spec B 6 speed: .707 Final drive: 3.54 I combined a 06 STI 6 speed with the 5-6 cluster gear from a Legacy Spec B. I get the .707 with a 3.9 final drive. 53 at 2000 rpm on up to 77 I think at 3000.
'92 SVX LS Pearl White - 6mt Last edited by dragoontwo; 08-21-2013 at 03:32 PM. |
Even with my shoddy engine, leaking exhaust and code yellow 4EAT VTD I get around 31 on highway.
The last trip in Denmark this summer, 2 adults 2 kids, vacation loaded and zero topographic drama, saw speeds of 84 mph in average (typically between 75 and 95) with this mileage. Commute is bendy B-roads, mountain pass, some highway and city jam is more like 24-25 mph . I step a lot on it during the ~25 km "scenic" part. Like climbing the pass at WOT and stuff like that. FD is 3.7
I got my girl, I got my glass, I got my car and I'm ready to f... Last edited by jetboy; 08-13-2013 at 03:39 PM. |
Lucky. With my sliptastic 4EAT I'm lucky to get 24 mpg highway...
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
